2000 SIR suspension setup
Old Aug 12, 2003 | 10:25 PM
lastlude2k1se's Avatar
Default 2000 SIR suspension setup
I just autoXed for the first time with my new suspension setup that was installed a month ago(Tokico Illuminas with Tein S. Tech's) and it was pretty good b/c I've never had upgraded suspension B4. I'm wondering if the H&R Cup Kit is alot better, or are they pretty close in performance? Reason I'm thinking of switching so quickly is b/c a friend wants to buy my setup from me instead of waiting for it to be ordered. I wasn't overly impressed with the S.Tech spring rates as well.
So Tein S. Tech/tokico Illumina < H&R Cup Kit?
Thanks
Old Aug 12, 2003 | 10:35 PM
Draggin99Si's Avatar
Default Re: 2000 SIR suspension setup (lastlude2k1se)
I read that the H&R Cup Kit are really Koni Yellows painted silver, and those are matched with H&R Sport springs. So if that's true, then you have....
Koni Yellows/H&R Sports vs. Tokico Illuminas/Tein S-Tech
Old Aug 13, 2003 | 07:37 AM
Default Re: 2000 SIR suspension setup (Draggin99Si)
Yeah that's what I found out as well. So which setup is better? Is it worth swapping out the H&R/Koni Yellows for my Illumina/S. tech setup?
Old Aug 13, 2003 | 09:19 AM
RZFD's Avatar
Go for the cup kit. First off the S.Techs are not much stiffer than stock, they don't call them "dress up masters" for nothing. Not to mention Tokicos aren't **** when compare to Konis. Getting a specifically valved spring/shock combo is usually the best idea if you're not going with a full coilover setup. I myslef plan on getting the Koni RSK kit since I don't need the adjustability right now. Try shox.com.
David12
Suspension & Brakes
16
Mar 3, 2010 05:25 PM
candy eg
Feb 9, 2005 06:38 PM
zm_dawg
May 11, 2004 12:03 PM
BrokeAssAcura
Apr 23, 2004 09:12 PM
NCSTIdriver
Oct 29, 2002 09:14 AM
