JDM Exhaust? Will it work with my setup, where to get, and how much?
Old Aug 11, 2001 | 03:23 AM
onyx00's Avatar
Default JDM Exhaust? Will it work with my setup, where to get, and how much?
Alright, so I was thinking, since I have to get a 2.5" exhaust, why not go with the JDM system. I have the JDM 4-1 header, and a testpipe, which are 2.5". So isn't the JDM 2.5" all the way through? Thus I could just use a JDM part from the test pipe back to the muffler and use the JDM muffler.
Is this correct? Will my performance from it be decent?
If so, where can I get one and how much? (e-mail me if you have one, or can get one, onyx00@asu.edu)
Old Aug 11, 2001 | 07:32 AM
Benjamin Tang's Avatar
Default Re: JDM Exhaust? Will it work with my setup, where to get, and how much? (onyx00)
as far as i know the jdm itr exhaust is the same as a usdm one. the reduction in pipe dia. is in the flange area where it joins up with the cat.
either way... 2.5" exhaust is only good for forced induction where you want to reduce backpressure. i think you would actually lose power with a 2.5" on a NA car.
[Modified by Benjamin Tang, 8:34 AM 8/11/2001]
suesky
Jun 8, 2011 09:17 AM
Rdriven
Jun 30, 2002 11:45 PM
comptechgsr
May 20, 2002 09:26 PM
comptechgsr
May 18, 2002 11:39 AM
houston
Mar 6, 2002 04:28 AM
