Where is the EVAP purge valve on 99 Si?
Old Aug 12, 2003 | 09:34 PM
LiLOtaku's Avatar
Default Where is the EVAP purge valve on 99 Si?
I'm running hondata and have been experiencing bad idle at startup, after a previous drive. Hondata says to pull the EVAP purge valve, I just wanted to make sure I pulled the proper connector.
Its the brown connector on the passenger side of the fire wall. It's connected to a black plastic canister.
Old Aug 12, 2003 | 10:03 PM
Civic Power's Avatar
New User
Default Re: Where is the EVAP purge valve on 99 Si? (LiLOtaku)
on top of your fuel rail it is black
#8 in the pic
Hope that helps
David
Old Aug 12, 2003 | 10:35 PM
LiLOtaku's Avatar
Default Re: Where is the EVAP purge valve on 99 Si? (Civic Power)
Thanks Dave,
I guess I pulled the wrong Valve connector. I pulled the Canister Valve instead of the Purge Valve.
Old Aug 12, 2003 | 10:46 PM
New User
no problem
Old Aug 12, 2003 | 11:19 PM
S2KP's Avatar
wouldn't upplugging that cause it to not work right?
Old Aug 12, 2003 | 11:50 PM
New User
Default Re: (Turbo_Siii)
yes
supercharged d
Aug 6, 2009 03:59 PM
91EF919
Jun 14, 2009 02:07 AM
djnikko
Suspension & Brakes
Jun 12, 2009 02:50 PM
Josh10e
Dec 14, 2004 04:54 PM
