TURBO CIVIC 99 SI (FULL RACE ENGINE) JDM SHOW STOPPER VA/MD/DC
ENGINE
B18C GSR BLOCK SLEEVED BY BENSON'S BLOCKS 84.5
STROKED TO 2.1L
CUSTOM 9:01 PISTONS
PAUTER RODS
NITRIDE TREATED CRANKSHAFT
TOPLINE BEARINGS
MOROSO OIL PAN
PRODRIVE OIL PUMP GEAR
INLINE PRO SFI 18.1 DAMPENER PULLEY (PROPS TO INLINE PRO)
BCE PRO DRAG HEAD
CUSTOM P/P
TITANIUM RETAINERS
MOLY COAT DUAL VALVE SPRINGS
STAINLESS VALVES
INLINE PRO INTAKE MANIFOLD
AEM FUEL RAIL
AEM CAM GEARS
CTR CAMS
CTR THROTTLE BODY
COMETIC HEAD GASKET
SX -6 FUEL PRESSURE REGULATOR
-8 FUEL LINES WITH FITTINGS
SX SLIM LINE FUEL FILTER
SFI APPROVED SCATTER SHIELD
SCT STAGE 4 CLUTCH
ITR FLYWHEEL
B16 TRANNY
HASPORT STAGE 2 MOUNTS
CTR VALVE COVER
CTR OIL CAP
TURBO
GTR SKYLINE INTERCOOLER CORE
TURBOSMART PRO-GATE WASTEGATE 45MM (V-BAND FLANGE)
HKS SS BOV
TO4X2 XS ENGINEERING TURBO 88 TRIM (POLISHED HOUSING)
3.5" DOWNPIPE V-BAND FLANGE
2.75" TURBO PIPING
CONSTANT TENSION PIPING SPRING CLAMP
SILICONE COUPLINGS
CUSTOM AUTOSOLUTION EQUAL LENGTH TURBO MANIFOLD
STEEL GASKETS
STAINLESS FEED LINES
STAINLESS -8 RETURN LINE W/ FITTINGS
GREDDY TURBO TIMER
GREDDY PROFEC B BOOST CONTROLLER
1000cc INJECTORS
SKYLINE FUEL PUMP
HONDATA S200 SYSTEM
REPROGRAMABLE CHIP
HONDATA ECU
3 STAGE REV LIMIT OPTION
DATALOGGING OPTION
BOOST OPTION
FJO WIDEBAND O2 SENSOR W/ MONITOR
FUEL PRESSURE GAUGE (NOS)
IGNITION
MSD SCI
NGK IRIDIUM SPARK PLUGS
NGK WIRES
BLASTER 2 COIL
MSD CAP
KOYO RADIATOR
FAL FAN
NEW PAINT (GUNMETAL BRONZE)
16 INCH ROTA'S W/ SPARE (5 TOTAL W/TIRES)
CTR HEADLIGHTS
CTR MIRRORS
AXXIS METAL BRAKE PADS
ALL AROUND BREMBO CROSS/SLOT ROTORS
MUGEN FRONT LIP
SI REAR LIP
SI WING
HKS CARBON TITANIUM EXHAUST
3.00 INCH CUSTOM CATBACK
AUTOMETER TACH
REVERSE EL GAUGES
BROADWAY MIRROR
AUTOMETER GAUGES (BOOST AND A/F)
SKUNK 2 SHORT SHIFTER W/ SKUNK2 ****
CF HOOD
CTR SHIFT BOOT
VENTED REAR BUMPER (DIFFUSER)
FRONT EXTENDED WHEEL STUDS
MAGNESIUM WHEEL LUGS
EXTRA SET OF WELD DRAG RACING RIMS 15*10
STAINLESS STEEL BRAKE LINES
SKUNK2 DRAG COILOVER SYSTEM
KONI RED STRUTS
PIONEER HEADUNIT W/ MB QUART SPEAKERS
VIN 1HGEM1150XL047937
more pics 2 follow
ASKING 19,500 obo MAKE SERIOUS OFFERS.
http://www.autosolutionva.com
STROKED TO 2.1L
CUSTOM 9:01 PISTONS
PAUTER RODS
TOPLINE BEARINGS
MOROSO OIL PAN
BCE PRO DRAG HEAD
CUSTOM P/P
TITANIUM RETAINERS
STAINLESS VALVES
AEM FUEL RAIL
AEM CAM GEARS
CTR CAMS
CTR THROTTLE BODY
COMETIC HEAD GASKET
SCT STAGE 4 CLUTCH
ITR FLYWHEEL
B16 TRANNY
CTR VALVE COVER
CTR OIL CAP
TURBO
HKS SS BOV
2.75" TURBO PIPING
SILICONE COUPLINGS
STEEL GASKETS
GREDDY TURBO TIMER
1000cc INJECTORS
SKYLINE FUEL PUMP
HONDATA S200 SYSTEM
REPROGRAMABLE CHIP
HONDATA ECU
DATALOGGING OPTION
BOOST OPTION
IGNITION
MSD SCI
NGK WIRES
BLASTER 2 COIL
MSD CAP
KOYO RADIATOR
FAL FAN
CTR HEADLIGHTS
CTR MIRRORS
MUGEN FRONT LIP
SI REAR LIP
SI WING
AUTOMETER TACH
REVERSE EL GAUGES
BROADWAY MIRROR
CF HOOD
CTR SHIFT BOOT
KONI RED STRUTS
more pics 2 follow
Old setup did about 450hp. This is a whole new engine turned over a couple times. Maybe 25 miles on new engine. Chassis has about 93K on it..clean in and out. Have raced 11sec RX7's and stayed side by side the whole time on old setup. New setup should net mid 10s high 9s on slicks.
weren't you just selling a turbo h22 the other day? This car looks sick. Have any more pics of the engine compartment?
