Whats is the benefit of Final gear 4.785.....
Old Aug 10, 2001 | 10:02 PM
powerfulperformance's Avatar
Default Whats is the benefit of Final gear 4.785.....
what is the purpose on this gear.......
Old Aug 10, 2001 | 10:09 PM
Downey's Avatar
Default Re: Whats is the benefit of Final gear 4.785..... (powerfulperformance)
it brings all your gears closer together. Shortens the final drive. For example, my civic cx can do 66mph at almost redline in second gear. If i got a Civic EX or Si transmission that has a shorter final drive i would have to shift into 3rd a bit sooner than 65mph. Soory for the shitty response, im tired!
Graham
Old Aug 11, 2001 | 03:37 AM
DutchITR1689's Avatar
Faster acceleration but lower top speed if you don't change the rest. That's it....
Old Aug 11, 2001 | 05:43 AM
Dipshit Dan's Avatar
Default Re: Whats is the benefit of Final gear 4.785..... (EuroITR1689)
Actually since top speed is drag limited and not rev limited I believe top speed stays the same.
Old Aug 11, 2001 | 06:26 AM
BryanSprinkel's Avatar
Default Re: Whats is the benefit of Final gear 4.785..... (God)
What are the speeds reached at about 8400 with the final drive, in 3rd and 4th? (also with the GSR fifth gear?)
Bryan
Old Aug 11, 2001 | 07:01 AM
Hukd Up's Avatar
Default Re: Whats is the benefit of Final gear 4.785..... (VAtypeR00)
i know the answer to this question has about a million variables to take into consideration, but roughly, if the stock 1/4 time of an itr is 14.7, what can someone expect to run with a jdm final drive and lightweight flywheel?
thanx.
jason
Old Aug 11, 2001 | 07:15 AM
I don't agree with this. If your final drive is, let's say 5.500 then you won't reach your actual top speed that is determined by drag. You will hit the rev limiter first before the drag is at its maximum. The same case when you mod your engine and you gain like 50 hp. Your top speed will be much higher if you get a longer 5th gear or final drive. Otherwise you will hit the rev limiter first before the drag equals to the engine power. Also after the peak rpm your power will drop. The ideal gear ratio for top speed is when you reach your top speed (determined by drag) at peak power rpm in the highest gear.
Old Aug 11, 2001 | 11:25 AM
RagingAngel's Avatar
All I know is...the benefit of greatly noticed when running on the circuit....
but also driving TO the circuit....
5200rpm INDICATED on the tach at a little over 140kph.... WITH a Zigen 304 N1 catback fitted with testpipe WITH the silencer curiously missing....
ARGHHHHHHHH!!.... earplugs indeed!!
Old Aug 11, 2001 | 03:08 PM
JDM BOSS's Avatar
check out Katman's B-series spec page.. there's some useful info on there...
http://ff-squad.com/Bgears.htm
[Modified by schao, 4:09 PM 8/11/2001]
5zigen_dc5
Mar 31, 2006 05:06 PM
RS_91
Aug 27, 2003 07:31 AM
Dorikamu
Jun 20, 2002 11:39 AM
R2D2
Jun 17, 2002 07:40 AM
