H.I.D. Problem?
Old Aug 12, 2003 | 05:12 PM
Andres-eh2's Avatar
Default H.I.D. Problem?
I recently installed a set of Audi A6 HIDs on my car. My friend got me a set (legit) but the bulbs were different. 1 Osram 35W, 1 Philips 35W. Both are D2S
They light up great but for some reason when they warm up theyre the same color and when theyre set one looks a little yellow and the other normal white HID.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by http://faq.auto.light.tripod.com/hl-hid-bulbs.htm &raquo;</TD></TR><TR><TD CLASS="quote">
After passing around 100-500 hours the phenonmen "color shift" will take place. Color will change slightly from a yellowish tone to a crisper bluer tone. The magnitude of color shift will vary depending on brand, model and rated color. It is a very gradual change and unless paid close attention to, a customer might not notice. OEM 4100K Bulbs manufactured by Philips has been reported to have a more noticeable color shift than OEM 4100K Osram. OEM 4100K Bulbs manufactured by Philips has a colorshift of approx 250K after 500 hours, which will bring it to up to 4350K.
Is this the answer??
TIA
Not noticeable in the pic.
Old Aug 12, 2003 | 05:15 PM
ophdehEEzY
Guest
Posts: n/a
Default Re: H.I.D. Problem? (EGEESIX)
bump
I wanna know too
Old Aug 12, 2003 | 05:39 PM
bryant's Avatar
Well, maybe 1. you have two different bulbs. 2. your headlights could be dirts. 3. maybe the lense is dirty.
Old Aug 12, 2003 | 06:06 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I would suspect the bulbs are different ages. Phillips is coming out with a 5000K bulb (not tinted) specifically for cars w/ OEM HID in which one bulb has gone out for whatever reason, and these 5000K bulbs will more closely match their other bulb (if you replaced it w/ a brand new D2S it would be more yellow than the older bulb).
So yeah, most likely the 2 bulbs have different amounts of hours of use on them.
Old Aug 12, 2003 | 06:09 PM
Andres-eh2's Avatar
both these bulbs are from an audi oem hid kit. i didnt buy any new bulbs.
Old Aug 12, 2003 | 08:54 PM
Andres-eh2's Avatar
Anyone Else?
Old Aug 12, 2003 | 10:11 PM
MTK Kommander's Avatar
Default Re: (EGEESIX)
in comparison, osram HID has more of a purple output, and the philips has more of a sky blue color.. but the reason you're seeing so much yellow is because they arent shielded.. the color shift thing might be an answer, but as far as the 2 bulbs go, they have different color outputs even brand new when side by side..
street_ride14
Lighting
Aug 26, 2011 02:08 PM
Importn2oRacer
Acura TL, RL & ZDX
Oct 11, 2007 04:58 AM
nathanong87
Jun 22, 2005 06:39 AM
BoostedVtecGsr
Acura TSX
17
Mar 30, 2005 09:43 AM
jrthecow311
Feb 21, 2005 08:18 AM
