uping compresson by use of a thinner head gasget
Old Aug 12, 2003 | 04:26 PM
bluedevil's Avatar
Default uping compresson by use of a thinner head gasket
trying to get the most compresson out of a stock b16a motor with out milling the head.its the first gen with 10:2 COMP. I was thinking ether spoon head gasket or taking a layer a so off of the stock one. ps iam also running stock cams. thanks for any help any one gives.
Modified by bluedevil at 5:52 PM 8/12/2003
Old Aug 12, 2003 | 04:37 PM
Padawan's Avatar
Darth ModerVader
Default Re: uping compresson by use of a thinner head gasget (bluedevil)
Either choice will give you a slight bump in compression. Keep in mind that anytime the head is brought closer to the block (either by milling or with a thinner gasket), your cam timing will be affected.
Old Aug 12, 2003 | 04:57 PM
bluedevil's Avatar
can anybody give a wild guess on how much bump up of compression will it go to 10:5 etc........
Old Aug 12, 2003 | 05:03 PM
Padawan's Avatar
Darth ModerVader
Default Re: (bluedevil)
With a Spoon or Mugen gasket, you will probably see roughly a 0.3 point gain.
Old Aug 13, 2003 | 08:44 AM
advanracing62's Avatar
Default Re: (Padawan)
didn't we just go over this in a similar thread?
integraman 95
Nov 7, 2007 02:59 PM
ricearoni56
Nov 12, 2004 08:20 AM
JDMlyfestyle
Mar 25, 2004 01:35 PM
snake01
Nov 13, 2002 03:26 PM
RTW DC2R
May 24, 2002 06:52 AM
