Wrong clutch for b16a...
My friend is swapping SirWanabes hatch, with a cable-type first gen b16a. He bought a 94 del sol VTEC hydro ACT 6 puck clutch and it wont fit on the cable J1 trans.....what year model clutch do we need to fit the J1? 90-91 b18a teg? TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vap133 »</TD></TR><TR><TD CLASS="quote">Yes, get a 90-91 Teg clutch....
Yep...a friend of mine made the exact same mistake even though i told him to get a 90-91 teg clutch!
</TD></TR></TABLE>Yep...a friend of mine made the exact same mistake even though i told him to get a 90-91 teg clutch!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kanzenr91si »</TD></TR><TR><TD CLASS="quote">the 92-93 gsr clutch fits the ys1 trannies. 90-91 integ clutch fits j1,s1,y1. </TD></TR></TABLE>
It also fits the 92-93 LS trannys as well, its what i have in my car right now (are all 92-93 teggy trannys labeled YS1 whether it be a GSR or LS??).
90-91 teggy clutches are for those years only and the JDM B16 trannys.
92-93 teggy clutches are for any 92-93 teggy 5 speed tranny.
Like what they said......also, make sure you get the right throw out bearing for the cable trannies. The B-series cable and hydro clutches can share the same pressure plate, but there will be differences in the ThrowOut bearing and splines for 92+newer Integra applications.
[QUOTE=HandCommand]Like what they said......also, make sure you get the right throw out bearing for the cable trannies. The B-series cable and hydro clutches can share the same pressure plate, but there will be differences in the ThrowOut bearing and splines for 92+newer Integra applications.[/QUOTE
I had the wrong throw out bearing too, dammit.
But the new clutch disk and pressure plate (90 teg) and throw out bearing are on the way.
I searched in the archives for the info on what clutch to buy, I was mislead. : (
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX.HF »</TD></TR><TR><TD CLASS="quote">I have an ACT Stage3 for a B16A2 (Yes, 99-00 Civic SI, Hydro) in my B16A JDM tranny. If that matters any...
And works 100% flawless.</TD></TR></TABLE>
On a y1/s1/j1? Thats weird
I'm pretty sure it's a YS1 due to the intermediate shaft that came with it, cable none the less.
Car pulls and grabs hard, no slippage. Runs flawless.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX.HF »</TD></TR><TR><TD CLASS="quote">I'm pretty sure it's a YS1 due to the intermediate shaft that came with it, cable none the less.
Car pulls and grabs hard, no slippage. Runs flawless.</TD></TR></TABLE>
Ahh...YS1 would be a 92+ tranny which means the press plate and disc will fit even though its from a b16A2. Now like the others said, the throwout bearing wont work << been there done that.
So CRX HF do u have a YS1 USDM GSR tranny or USDM LS tranny? Did a cable JDM tranny ever come marked YS1?? i dont believe so...
It's most likely a USDM B17A YS1 at this point, I thought the thread was about hydro clutches not working on cable transmissions.
Altho I thought I had a B16A JDM prior to posting, but I don't think so now since the gearing is a tad longer than I expected, since my friends 2100lb coupe with a B16 has the same gear feeling as me, at 1600lbs.
My apologies for the confusion if not.
