Ground Control and spring rates
Is it possible to tell the spring rates on a set of Ground Controls by looking at the printing on the springs? If so, can someone decipher: 200.64.67 (fronts) and 180.64.44 (rears). Thanks!
If I had to take a SWAG, I'd say, 200 lb/in, 2.5" spring (64mm is about 2.5"), and 180 lb/in, 2.5" spring. No idea what the last number might be.
Are they Eibachs? They should have come with either an engraved number on the end of them, or a sticker with the tested spring rate. Springs are usually slightly off, so they stick them on coil testers for accurate numbers.
Warren
Warren
Yeah they're GC/Eibach springs. The front springs say Eibach 61301/GC200.64.67 and rears say Eibach 62663/GC180.64.44
The rear springs appear pencil thin.
