broken sunroof
i think the task would be more of a pain than difficult. you will need to remove the headliner, then drop the sunroof out. after that you should be able to remove the glass panel and get it replaced.
i have only worked on civic sunroofs and you def. need to drop them to remove the glass...
Yeah Keith is right... you have to drop the entire assembly to remove the pannel... Btw, Crx's only came with body matched pannels so you may have an aftermarket sunroof which may make it a little harder to find a replacment...
Hawkrider
May 5, 2009 04:30 AM
msinsky14
Dec 30, 2007 06:10 PM
travis
Apr 11, 2002 09:22 PM
