Civic heater core doesn't work with Integra climate controls
Old Aug 12, 2003 | 07:49 AM
SpoonFedHatch's Avatar
Default can somebody PLEASE explain....
why the CIVIC heater core (under dash) does not work with the INTEGRA climate control??? i get ICE COLD air blowing for the a/c, but the heater does not work....any ideas?? (ps, i did an ITR dash swap) thanks in advance
Old Aug 12, 2003 | 08:35 AM
len's Avatar
len
Default Re: can somebody PLEASE explain.... (SpoonFedHatch)
Check to see if the wire that controls the flap is the proper length. Also check the water valve to see if it opens and closes properly. As long as you have hot radiator fluid flowing through the pipes and the heater core then you should have heat, unless you have a bad/leaking heater core.
Old Aug 12, 2003 | 08:47 PM
well len, i KNOW my heater core is in good condition......i will check to see if the wire is proper length.....thanks for the help
Old Aug 14, 2003 | 10:55 AM
Default Re: (SpoonFedHatch)
well the wire appears to be the proper length....it is just the same as the civic's wire controller ( the door puller)......i'm thinking it may be electrical.....any help is appreciated, and thanks again for the above input
Old Aug 15, 2003 | 04:25 PM
bump?
Old Oct 2, 2003 | 10:44 PM
ok it's getting cold out....any ideas??
is there a difference between civic and integra a/c harness??? it plugged right up, but now the heater doesnt kick on....
can anybody inform me onhow to tell if the "heater door" is working??
Chewy Built !
Aug 25, 2009 09:45 PM
Playboy07
Jan 28, 2006 12:18 PM
speedyR
10
Mar 21, 2004 06:37 AM
SpoonFedHatch
Aug 12, 2003 07:48 AM
integra0260
Jul 6, 2001 09:34 AM
