Binding front brakes
Old Aug 12, 2003 | 04:16 AM
James's Avatar
Default Binding front brakes
I know it is a common topic, but my 92 accord front brakes are binding somewhat and I plan to take the calipers out and clean them, but is there anything I should be concerned that would cause the front brakes to bind. Does it mean that I would need new calipers? (Or rebuild the calipers) The rear brakes seem to be fine. I plan a trip to Maine and would like to be sure that the front brakes are operating properly. The calipers are orignal and my car has 170k miles.
Thanks-
Jim
Old Aug 12, 2003 | 06:15 AM
JimBlake's Avatar
Default Re: Binding front brakes (James)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by James &raquo;</TD></TR><TR><TD CLASS="quote">... and I plan to take the calipers out and clean them, but is there anything I should be concerned that would cause the front brakes to bind. Does it mean that I would need new calipers? (Or rebuild the calipers)...</TD></TR></TABLE>
Depends on what you find when you clean them. Make sure the caliper slide pins move nicely. Take a good look at the clips/springs that hold the pads. The pads have to be able to move away from the disk slightly, when you release the brakes.
If you can clean & straighten all that stuff, then you're OK. If anything's beyond fixing then you need a new caliper. As long as you're taking them apart, you might want to put new pads in anyway.
bobnbeck
Oct 25, 2017 05:29 PM
Mr.Speed
Sep 22, 2008 02:33 PM
93civicjaydm
Honda Civic (2006 - 2015)
17
Apr 23, 2008 09:19 AM
vtec95
Acura TL, RL & ZDX
Jan 23, 2008 01:01 AM
Sinner
Dec 19, 2005 08:00 PM
