H22A4 injectors conversion in a swap
I have a 95 JDM H22A in my 1997 Accord. Even though my Accord is OBDII, it has a resistor pack. I was once told that the 96-97 Accords really aren't completely OBDII. Rumor is that they are OBDII with just additional sensors or something.
Problem is that I found a guy selling a fully built H22A4 block. Can I use the peak and hold injectors of my H22A head on the H22A4 (which I assume uses saturated injectors)? If not, what must I do to match the block and head up.
Another question: My H22A tranny should work on the H22A4, right?
As long as you keep your harness, use your h22a injectors. Now from what I understand, the h22a4 that was in the SH has a different intermediate axle setup and bolt holes. So, just make sur you aren't getting a type SH h22a4, and it will bolt right up.
Mike
Mike
BlackCRX
Aug 22, 2007 04:23 PM
