help - brake master cylinder leaking fluid
Old Aug 11, 2003 | 08:24 PM
stripes777's Avatar
Default help - brake master cylinder leaking fluid
my 1992 civic hb cx is, the brake master cylinder, where it touches the big black round metal thing, seems to be leaking out fluid man, ****, haha. what can cause this and how do i fix it. when u buy a new master cylinder, is that big round thing included too, or maybe i dont even need a new one, help please, thanks
Old Aug 11, 2003 | 09:38 PM
allmotorEG-SI's Avatar
Default Re: help - brake master cylinder leaking fluid (stripes777)
That "big black round metal thing" is your brake booster and a leaky M/S can let brake fluid get into you booster and wear out the diaphram in it causing a loss in pressure which will mean its no good and has to be replaced. But thats not always the case. When you press real hard on the breaks does it slowy go to the floor? if so your booster might be bad. But you might want to check just to see if your M/S has a busted gasket. Otherwise their real easy to replace. The booster though is the biggest pain in the ***!!!
Old Aug 13, 2003 | 02:17 AM
stripes777's Avatar
it doesnt go down, it jus leaks fluid from where i said. do u think its possible that the gasket broke and i need a new one.
i never paid any attention. but other peoples cars. when u shut it off and the next day, before u start the car, is the brake pedal pressurized? mine seems to be pressurized already, before i start the engine.
thanks
Old Aug 17, 2003 | 01:44 PM
stripes777's Avatar
anyone?
Old Aug 27, 2003 | 01:14 PM
stripes777's Avatar
can someone please let me know about their brakes in my question in my second post, thanks
Old Aug 27, 2003 | 09:04 PM
Default Re: (stripes777)
i'm not sure what you mean by being pressureized. But it should usually be pretty firm. If you have a soft peddle you have problems
Old Aug 27, 2003 | 09:07 PM
MrIllegalX's Avatar
i just replaced my M/S because it was bypassing, and it gave life back to my brakes, but my pedal is still soft, so i guess I need a booster too, or maybe I have air in my lines. Either way I'd get both replaced on your car.
And yes, your pedal should be firm when your car isn't running.
another eg
Sep 1, 2015 04:31 PM
PhilE2212
Suspension & Brakes
Nov 7, 2012 10:08 AM
PhilE2212
Nov 2, 2012 08:26 PM
mattmw88
Mar 31, 2008 06:08 PM
PatrickGSR94
Jul 15, 2002 02:13 PM
