G2 signal lights help
If i remember correctly, you should remove one screw near the top of the headlight (underhood). Then pop it off towards you assuming you are face to face with the car. Then that's it.
I had that same problem with my car. I used a nice long flathead screwdriver and pryed them off. Sounds kinda harsh but it worked for me! Be careful not to bend anything while you're doing it though
An alternate solution would be to remove the front bumper then you can easily just pop the bulb out without removing the corner light. I never could get that darn corner light assembly off(without first removing the bumper)because I felt like it would break with too much pressure.
1991Ed7
May 22, 2011 11:51 PM
civicSIracer96
Nov 6, 2003 08:43 PM
