H22 VTEC Gears in a H23 NON-VTEC Tranny
Old Aug 11, 2003 | 05:42 PM
crj_lll's Avatar
Default H22 VTEC Gears in a H23 NON-VTEC Tranny
Will H22 VTEC gears fit in an H23 tranny housing?
Old Aug 12, 2003 | 11:12 AM
crj_lll's Avatar
Default Re: H22 VTEC Gears in a H23 NON-VTEC Tranny (crj_lll)
BUMP
Old Aug 12, 2003 | 04:07 PM
madcatz's Avatar
From what I understand the trannys bolt up to the blocks....Why not just buy a H22 Tranny....or yeah buy a H22 and do it that way, and go boost....or just learn your powerband with the Si tranny
Old Aug 12, 2003 | 04:13 PM
fastlude69's Avatar
Default Re: (madcatz)
i wanna know if you can swap gears in like a type r final in a gsr tranny. cuz i was wondering if h22 has a better final then the h23 cuz i'm going to rebuild mine and i want to build a good one tranny gurus help plz sorry to jack your post
Old Aug 12, 2003 | 09:16 PM
crj_lll's Avatar
Default Re: (fastlude69)
Talked to my honda parts man. The transmission housing has 2 parts. One side of the housing is the same on and H22 and an H23. The side that actually hols the gearing is the part that is different from the H22 from the H23.
Old Aug 12, 2003 | 10:15 PM
caz245's Avatar
Yes they will interchange , I already did it on my car, I had both trannys apart at the same time and they are identical except for the number of teeth on a couple of gears, and its only by one or two teeth on the ones that are changed. Also the final drives and diffs will also interchange, just be sure to set up the propper bearing clearance when you make the swap.
Old Aug 13, 2003 | 12:51 PM
crj_lll's Avatar
Default Re: (caz245)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caz245 &raquo;</TD></TR><TR><TD CLASS="quote">Yes they will interchange , I already did it on my car, I had both trannys apart at the same time and they are identical except for the number of teeth on a couple of gears, and its only by one or two teeth on the ones that are changed. Also the final drives and diffs will also interchange, just be sure to set up the propper bearing clearance when you make the swap.</TD></TR></TABLE>
So you have vtec gears inside of a non-vtec tranny???
Old Aug 14, 2003 | 01:56 PM
flyrod's Avatar
Default Re: (crj_lll)
They are not interchangable with the S model prelude or other common F22-mated trannies like from an accord. The H23 tranny might work though, I have not tried it. The final drive is the same though, so the only point would be to change some of the ratios on individual gears. Please let us all know what you come up with!
#1 luder
May 24, 2009 01:13 PM
yeahdudebrown
Oct 15, 2004 03:46 PM
greenli0n25
Nov 25, 2003 11:01 PM
