advice on h22a of f20b
Old Aug 11, 2003 | 03:57 PM
brains needed's Avatar
Default advice on h22a of f20b
what is everyones thoughts on the f20b accord sir motor versus the h22a prelude motor? from what i know, the f20b has 200 hp at 7200 rpms, 11:0 compression, 16 valve, 1997cc. the h22a has 200 hp at 6800 rpm, 16 valves, 2157 cc, and 10.6: compression. i know the numbers on the f20b look better overall, but then again, the h22a is more upgradeable as far as i know.
Old Aug 11, 2003 | 05:00 PM
CD8's Avatar
CD8
Default Re: advice on h22a of f20b (brains needed)
the only downside i see to the f20b is the price tag. ive never seen one cheaper than a h22a. but ive only heard of a handful of those swaped.
Old Aug 11, 2003 | 05:05 PM
fizzbob7's Avatar
Default Re: advice on h22a of f20b (CD8)
it's a destroked h22a is all it is....designed to be able to compete in the btcc and they needed to meet the 2.0 liter and under rule.........it's a b series like motor...needs to rev to make power....put one of those in your accord, and you'd be running slower for more money.....here is a link with some more info......it's different, but not practical....it makes the same power, less torque and has a peakier powerband......not bad, but not as good for most applications...check this out
http://www.cb7tuner.com/vbb/sh...d=262
Old Aug 11, 2003 | 08:28 PM
Default Re: advice on h22a of f20b (fizzbob7)
thank you for all of your advice. i checked out that link, and it helped me out a lot, and answered all of my questions. now my only problem is, where to get either the jdm h22a or h22a type s?
Old Aug 11, 2003 | 08:57 PM
fizzbob7's Avatar
anywhere really.......type s is a waste unless you have the extra $2000 for 20 hp or if you wanna drop it in and not mod it...with an h22a and $1000 you can make more than the type s does.....it's a nice engine, but a bit pricey to me.....go obd 1 h22a w/lsd tranny and you'll be happy....an intake, stock header, 2.5" exhaust and some cams and tuning and you'll be pretty quick...
Old Aug 11, 2003 | 11:21 PM
Bowlergi21's Avatar
Try http://www.hmotorsonline.com or http://www.osakajdmmotors.com
I've gotten motors from both and are very clean and run great!
Old Aug 12, 2003 | 04:57 AM
v4lu3s's Avatar
RTFM
Default Re: advice on h22a of f20b (Bowlergi21)
you got a clean motor from asaka? did you go pick it up yourself?
most people get **** motors from osaka....
Old Aug 12, 2003 | 11:52 PM
Bowlergi21's Avatar
Default Re: advice on h22a of f20b (v4lu3s)
One of my buddies got a cleanass Integra type R motor from there and it runs like a bat out of hell. What kind of experience have you had with osaka?
Old Aug 13, 2003 | 04:51 AM
v4lu3s's Avatar
RTFM
we bought ONE Motor through them
the parts damaged included a broken power steering pump, borken power steering pump pulley,
a hole in the oil pan
broken tps and knock sensors
no mounts or axles
incomplete header
and it was a dirty engine
Then they never said they would replace anything, I think my partner may have had his attorney write them a letter to get them to replace the broken parts.
A buddy of mine recently got one from there and he got a good one since he picked it up. He also pulled the head off while he was there to make sure it was internally in good condition.
Before that another friend got an h22a that would appear to be a fire recovery judging from the type of damage it had, and the markings on it.
Then the replacement they sent him for $350 more has low enough compression on stock pistons that his f22 felt as strong as it...
oh yeah and you can search on here for the in general bad feelings towards them as well for selling poor quality engines and no customer services.
xxx99ludexxx
Jan 30, 2016 04:27 AM
otacon122
Oct 28, 2008 05:13 PM
CRX 2.0V-T
Jun 22, 2006 10:49 PM
Neondog82
Jun 18, 2004 01:15 AM
