crank and bearing question
Old Aug 11, 2003 | 11:50 AM
civickiller's Avatar
Default crank and bearing question
ok i spun a rod bearing and it scored the crank journals so i gotta have a machine shop shave it down and make it all smooth again. my question is can i use another set of stock rod bearing from honda ? i mean after they grind it down, will the stock new rod bearing fit or do i like need to get some special made, or just liek a whole new crank ?
thanks
Old Aug 11, 2003 | 12:04 PM
RexB16's Avatar
Default Re: crank and bearing question (civickiller)
well first of all, i have a question for you. is this a stock more that's getting all this work done? b/c if so i highly suggest not going thro that much hassle and just replace the motor. even if its a b16.
as far as the bearings go, you are going to have to look up a color code for them based on how much the machine shop takes off you crank.
Old Aug 11, 2003 | 12:18 PM
Default Re: crank and bearing question (RexB16)
its an ls. i normally would get another motor, but i live in hawaii and its really hard to find motors here, and to ship a motor here is price because i gotta pay the price of the motor then shipping to hawaii. but the guy i bought the motor from is gonna pay for it so i dont gotta worry about the costs, as long as its under 400
can u tell me more about this color code thing for the bearings and stuf
Old Aug 11, 2003 | 01:13 PM
RexB16's Avatar
well basically main bearings are assigned a color based on thier thickness. you would have to look up the right color you need based on how much material the machine shop takes off. the machine shop should be able to tell you. if not call honda parts dept.
Old Aug 11, 2003 | 02:36 PM
oh ok thanks man
skatebaker6
Jan 12, 2011 07:35 AM
Prudz_lude
Jan 11, 2010 08:14 PM
.Grimace
Mar 10, 2008 09:53 PM
mySIisLOVE
Feb 25, 2008 11:54 AM
scratchy
Mar 17, 2004 02:49 PM
