about timing gears, bent valves, and compression
Old Aug 11, 2003 | 09:55 AM
tha Big EZ's Avatar
Default about timing gears, bent valves, and compression
I just noticed that when i get on it wot, my 96 h22a1 with 120,000 miles blows a little greyish smoke changing gears real hard. And maybe a little at vtec engagement. Noot real sure about it smokin a little when the vtec hits, it is more when changing gears real hard. Any way, i use mobile 1 syntec, or whatever its called, every time since 70,000 miles. why would it smoke? Next question: If i skipped 2-4 teeth on the cam, on the exhaust side, will theat bend my valves? Even if i checked the compresison and it is 180 across the board? And if I did slightly bend some valves would that cause it to smoke a little?
Old Aug 11, 2003 | 12:36 PM
tha Big EZ's Avatar
Default Re: about timing gears, bent valves, and compression (tha Big EZ)
what, nobody even has a honda-tech opinion on this? no personal this happened to me, but it was this stories? Sad. Anywhoh, i appreciate the info before hand!
Old Aug 12, 2003 | 05:07 AM
tha Big EZ's Avatar
this is a sad sight. I mean, its a good question!
Old Aug 12, 2003 | 05:19 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha Big EZ &raquo;</TD></TR><TR><TD CLASS="quote">I just noticed that when i get on it wot, my 96 h22a1 with 120,000 miles blows a little greyish smoke changing gears real hard. And maybe a little at vtec engagement. Noot real sure about it smokin a little when the vtec hits, it is more when changing gears real hard. Any way, i use mobile 1 syntec, or whatever its called, every time since 70,000 miles. why would it smoke? Next question: If i skipped 2-4 teeth on the cam, on the exhaust side, will theat bend my valves? Even if i checked the compresison and it is 180 across the board? And if I did slightly bend some valves would that cause it to smoke a little? </TD></TR></TABLE>
explain how you think you might have skipped a few teeth
180 seems a little low for a 96 vtec but not to bad.
Driven
May 19, 2006 07:53 AM
98itr0448
15
Nov 18, 2004 07:56 AM
98Preluder7
Oct 26, 2004 09:40 PM
NSTY Z33
11
Sep 6, 2004 02:24 AM
