JDM DC5 Type R ecu on RSX TYPE S
ok recently i bought the JDM DC 5 Type R ecu for my RSX Type S.. b/c i was told it would work... i admit im not a gear head just yet so i really dont know what to do but slap it on and see if it works... is there anything else that i would have to do in order for it to work?
this is what i did...
disconnected the battery
took off the stock ecu
installed the new ecu
and tried to start it
the first attempt let me run for about one second and then it would die
and all the other attempt wouldnt even start
so obviously i have to do something else or the ecu is no good
if you know what to do please help me out!
thanks,
Josh
thanks,
Josh
our cars have immoblizers and you have to get the dealership to change the immoblizer code it if you want the jdm ecu to work. Otherwise get the ecu upgrade
jap cars dont have immoblizers
The JDM ECU is designed for the Japanese integra with different cams and compression ratio.
Not only does the Hondata flash outperform the JDM ECU on the RSX-S, it outperforms the JDM ECU on the JDM engine.
See:
http://www.hondata.com/k20arelease.html for dyno tests.
See:
Yeah, not the best investment in an RSX-S. Like he said: it's designed for the JDM engine. Even if it came from the same exact engine from Japan (which of course doesn't exist)... no immobilizer.
Oh, there's no "JDM ECU on the RSX-S" but I assume that's a typo and you meant RSX-R.
EDIT: The JDM RSX-R ECU doesn't allow the car to go over 110MPH by the way.
Like it was stated before the DC5R ecu would not work for our type S.
In japan the Integra type R's (RSX) do not come with the immobilizer.( I have no idea why they did not come with it, because so far it is helping us keep our cars.)
So what happens when we install the DC5R ecu into our cars is that it reads the immobilizer and does not find one. So the ecu then cuts the fuel and reads the immobilizer as an error and the car cuts the fuel off as a safety mode.
There have been a few people on http://www.clubrsx.com that purchased the DC5R ecu and made it work with some custom stuff. If you would like go there and do a search there. Good luck bro.
hey guys,
thanks a lot for the info...
i thought i just got ripped off, but i guess it just wouldnt work at all
well now i have to sell this thing... know anyone that wants to buy it
retails for about 850 bucks
where do i find that hondata ecu
and how much does that cost.
ps the guy that i bought it from, on eBay, said it would work
thanks again,
josh
thanks again,
josh
PearlSib18
May 8, 2003 08:18 AM
