Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
integra ECU on a B20B
Old Aug 11, 2003 | 08:16 AM
ppjanson13's Avatar
Default integra ECU on a B20B
Hi i have a 98 CRV with a supercharger...im installing the integra cams for better response, im wondering if the b18 non vtec ECU is better than the stock CRV ECU???
Would it be better to change it????
ANd the tranny, its seems to me that the gears fromn the b20 tranny are to long, what tranny should i get????
Thanks,
Old Aug 13, 2003 | 06:24 PM
AngelTeg's Avatar
Default Re: integra ECU on a B20B (ppjanson13)
Why would you change to Integra cams for a better throttle response? seems to me that CRV cams have a lower end grind, and provide a much better low end pull then Integra cams would. and as far as tranny stuff goes, just look up the gear ratios of your CRV and comapre them to Integra stuff. LS and GSR gears should go right into your tranny, and any B-series tranny will bolt right up.
as far as ECU goes, I don't think there is much difference between the two, you should check out ebay and switch to a chipped non-vtec ecu.
-Mike
Old Aug 13, 2003 | 11:04 PM
skud_dusty's Avatar
Default Re: integra ECU on a B20B (AngelTeg)
i was under the impression that the cams were the same, its just the intake manny thats different
but then again, im a dumbfuck sometimes
Old Aug 16, 2003 | 07:07 PM
bojangs's Avatar
New User
Default Re: integra ECU on a B20B (skud_dusty)
as far as i know ls and crv grinds are identical..
Old Aug 18, 2003 | 08:32 PM
94TurboGSR's Avatar
Default Re: integra ECU on a B20B (bojangs)
That makes 3 of us... the cams are the same.
exotik4doorcivic
Northwest (Sales)
10
Mar 9, 2009 01:13 PM
ppjanson13
Aug 12, 2003 03:34 PM
DaNish
Oct 8, 2002 06:05 PM
