Opinions, Please! Replacing my radiator. What do you think of this one?
Old Aug 11, 2003 | 06:08 AM
broncoman74's Avatar
From: Northwest Hills of, CT., United States of America
Default Opinions, Please! Replacing my radiator. What do you think of this one?
http://cgi.ebay.com/ebaymotors...70557
I may buy this radiator, Please let me know what you think of it? Being an inch thick, I will need to remove my air conditioning. I have only a pencil width of clearance between my header and the fan stock. My compressor is still good, But there is no refridgerant in the system anyway, So i figured I would get rid of the AC. Here is the guys website:
http://www.coolradiator.com
Thanks
Old Aug 11, 2003 | 06:54 AM
Doctor CorteZ's Avatar
Default Re: Opinions, Please! Replacing my radiator. What do you think of this one? (broncoman74)
why do you need that radiator ?
Old Aug 11, 2003 | 07:02 AM
4crx4me's Avatar
I had tried various options on the replacement radiator front,
and after a lot of money down the drain, broken water pump, aggravation, etc. I just bought an OEM for $300. Fit perfect ,solved all my problems. Case closed.
HTH
Old Aug 11, 2003 | 07:34 AM
Default Re: Opinions, Please! Replacing my radiator. What do you think of this one? (Doctor CorteZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">why do you need that radiator ?</TD></TR></TABLE> It is better than the one I have, Plus I plan on being buried in my car when I die of old age. I'm doing motor work hopefully this winter on the top and bottom end to beef it up for supercharging eventually. I figure I should get a better radiator since I need it (Stock radiator is leaking).
Old Aug 11, 2003 | 07:38 AM
Jet Black's Avatar
Depends on what you wanna do....unless you are gooing all out where every ounce costs......I'd got a good old Copper / brass radiator. Copper is one of the most hat conductive metals....plus copper can be soldered...so any leaks can be fixed with a propane toch and some flux.
autodriver
Honda CR-V & Element
Apr 24, 2012 05:19 AM
TOO MUCH TORQUE
Apr 4, 2011 05:10 PM
Herbie
Nov 6, 2006 02:38 PM
AccordRacing
Jul 25, 2005 06:44 AM
cecknight
Jul 13, 2002 06:52 AM
