What is this for sway bar?
looks like its part of whatever swaybar package that is.
chances are it only comes in that package.
the brackets probly mount onto that which mounts to your subframe. should help keep it from tearin
beaks makes something similar http://www.beaksproducts.com
https://honda-tech.com/zerothread?id=588882
found the pic here and i think i jus found the answer. mugen.
feel free to add, wanting some more info on this plate.
THIS IS THE CORRECT ANSWER!!!
Those are plates that King makes to reinforce the subframe. The two holes to the side go against the original sway bar mount holes, and the single hole goes against the LCA bolt hole. These plates take away stress from the subframe to help fight subframe tearout.
Modified by Damon at 11:27 AM 8/11/2003
bingo, makes perrrfect sense!
if you could, please get some pics of the completed instalation! i would really like to see what the clearance looks like with a possible tie-bar and such, thanx in advance!!!!
-Bryan-
-Bryan-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvinny »</TD></TR><TR><TD CLASS="quote">I think it to relocate the ABS.</TD></TR></TABLE> WTF??? where did you come up with that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cre18 »</TD></TR><TR><TD CLASS="quote">subframe reinforcement plates
Correct.... Kingmotorsports.com ships these standard with the mugen bars. You need them on larger bars to keep from ripping out your subframe.
