Problems after installing ZC trottle body on A6 .... Help !!
Old Aug 11, 2003 | 12:02 AM
sleeperx's Avatar
Default Problems after installing ZC trottle body on A6 .... Help !!
OK, I just finished putting a ZC throttle body and DC header on my D16A6. Here is the problem. When I push the clutch in and hold it or just go into neutral, my RPMs drop to 1500, then go up to about 2100 sometimes it will just stay there, other times after about 3 secs it will drop 800. Now the TB that I got didn't have a TPS sensor on it, so I took the one off my stock A6 TB (what a pain in the ***.) I noticed that the mounting holes for the TPS are oblong, I don't know if that is for adjustment or not. Any help would be great!
Thanks in advance.
Old Aug 11, 2003 | 08:38 AM
sleeperx's Avatar
Default Re: Problems after installing ZC trottle body on A6 .... Help !! (sleeperx)
come on .. someone has to have some kind of idea ..
Old Aug 11, 2003 | 08:54 AM
Steve91's Avatar
You have to adjust the TPS. Read the procedure in the Helms manual. If you don't have it adjusted properly, the computer will think the car is at part throttle.
Old Aug 11, 2003 | 08:56 AM
CimorelliCRX's Avatar
Default Re: Problems after installing ZC trottle body on A6 .... Help !! (Steve91)
the TPS is out of adjustment thats all you have to do is readjust it.
Old Aug 11, 2003 | 09:42 AM
sleeperx's Avatar
Default Re: Problems after installing ZC trottle body on A6 .... Help !! (CimorelliCRX)
awesome .. thanks guys
