b16 crx hf vacume line problem
can anyone post a pic of how to run vacume lines for a crx hf w/ a b16. i had a dx w/ a b16 before and i still have the whole vacume line assembly off the firewall but the plugs don't match up to the hf so i have to use the stock sensor and vacume lines. the hf has a whole lot more vacume lines coming off it and i don't know how to run the lines and which ones to cap off and tee. if anyone can help i'd really appreciate it.
the problem is that the hf map sensor box has 4 vacume lines runing from it. i know two go to the intake manifold but i don't know what to do with the other two. in the stock hf motor the other 2 lines went to that thing on the side of the manifold but the b16 dosen't have it.
eliminate line that you don't need, the less vacum line you have, that just a tiny bit more power........... what kind of problem are you having i have the same swap?
no problem with vac, lines here...........
crx1856
Aug 23, 2003 03:43 PM
crx1856
Aug 16, 2003 02:57 PM
