Probably asked a thousand times (Beware, much flamming may occur from this question)
Old Aug 10, 2003 | 09:32 PM
Origin's Avatar
Default Probably asked a thousand times (Beware, much flamming may occur from these question)
i tried searching, but maybe i was using the wrong keywords, but anyways i was wondering how hard it is to swap a b18c1 into an 1988 hf crx as far as wiring goes. i know it will fit but how much harder will it be to wire the thing. Also, if you have a direct link of the wiring that would be great, but im sure i could do a search on that and find something on it, but only do it if you have the time. Also, the same exact body length, width, and height stayed the same for the 88 to 91 crxs, but better options came on the cars for the higher models such as the si correct? thanks for your time.
Old Aug 11, 2003 | 01:14 PM
Origin's Avatar
Default Re: Probably asked a thousand times (Origin)
bump
Old Aug 11, 2003 | 01:41 PM
slowpokesi's Avatar
are you serious
https://honda-tech.com/zerosearch
CRX2007
Jul 25, 2005 04:58 PM
Dainbramage
Jun 1, 2004 05:13 PM
Xtream
Jan 31, 2004 02:35 PM
moridin2004
Jan 23, 2004 07:14 AM
