What would make the steering wheel shake??
Guest
Posts: n/a
I have warped brakes but everything else drivetrain wise is fine. I was thinking the rack-pinion steering "bar" (can't remember the technical term) could be going. What could I use to diagnose this and see exactly what it is, once and for all.
Guest
Posts: n/a
warped brakes would shake if u were going 80 then brake, and then it would shake. u can also take it to a shop to get it measured to see if they are warped. tire balance also a prop, most common is out of round tires, cupping, feathering due to alignment prob. tie rod bushing can also be too worn.(at the end of ur rack and pinnion)
its either unbalanced tires or warped rotors.
does it shake when you brake only or jus at high speeds (60+)?
if the car/steering wheel only shakes or vibrates when you depress
the brakes then its rotors. if not check tires uneven wear and then
balance them.
balance them.
EFing8
10
Aug 2, 2016 12:08 PM
NateJamesKapel
Oct 14, 2013 05:29 PM
