antenna mast removal
Old Aug 10, 2003 | 05:06 PM
Brad's Avatar
Default antenna mast removal
I tried unscrewing the special nut and pulling it out while the radio turned on, but it wouldn't budge. I took it apart and now I'm stuck. I can't remove it from the tube. Has anyone removed the mast from a 92-96 prelude before? How do you remove it? Here's where it's stuck:
Thanks,
Brad
Old Aug 11, 2003 | 10:00 AM
prelittlelude's Avatar
Default Re: antenna mast removal (Brad)
yea i ave doen this b4, **** its really hard to remeber, just pull really hard, if it doesn't come out somthing is jammed, did you take the motor assembly off i can't see in that pic or idon't remeber, but just pull.
Old Aug 11, 2003 | 12:13 PM
Brad's Avatar
Default Re: antenna mast removal (prelittlelude)
Ya I removed it from the motor assembly. The white part on the end of the mast gets stuck inside the metal tube when I try pulling it out. Is it just the silver mast that comes out or does any of the black part come off as well? How hard did you have to pull?
Old Aug 11, 2003 | 12:19 PM
im having a hard time remembering i did this when i first got my lude, if you look at antenna repair kits on ebay you can get an idea of what the completed non borken parts are supposed to look like. why are you taking the antenna apart any way? i think something is jammed in the tube, sorry im not much help.
Old Aug 11, 2003 | 03:09 PM
Brad's Avatar
I have the replacement antenna that I got off ebay. I wasn't able to pull out the antenna like the instructions said so I took it apart. I was pulling so hard that it was lifting the rear suspension up, I was afraid it was going to dent up the quarter panel. I can move the metal mast itself freely up and down the tube, it just gets caught on the white part on the end.....???
Old Aug 11, 2003 | 03:51 PM
LudeBoyLeRoy's Avatar
Yeah my PWR antenna is Fu@ked too due to the frozen tundra called Maine I think (ice)....so I just have it manually pulled-up like 16in...
On my old accord I removed it + replaced it w/a ghetto black Radio shack antenna that was about 16 in long and I angled it at a backwards angle (not best reception).
So I was thinking of pulling the broken pwr one & replaceing it w/something else.
Anyone used the Honda Insight (similar to Jetta/Focus one) or 'stubby' S2000 Antenna on a 4th gen Lude...or any gen for that matter? Does it look good? and for the Stubby S2000 one - does it get good reception?
Thanks...
DTMamg
Jul 2, 2010 10:15 PM
ricehero
Jan 11, 2006 07:41 AM
Crasian
Sep 3, 2005 07:08 PM
Yell00ITR
Apr 11, 2004 09:50 PM
Mikes94
Aug 28, 2001 10:39 AM
