Power Enterprise belt too loose......
Old Aug 10, 2003 | 04:44 PM
allmotorhonda's Avatar
Default Power Enterprise belt too loose......
Anyone ever have a problem with the PE belt being too loose even when the tensioner is as tight as it goes???
any suggestions??
Old Aug 10, 2003 | 06:16 PM
rathead's Avatar
Default Re: Power Enterprise belt too loose...... (allmotorhonda)
what motor?
Old Aug 10, 2003 | 06:20 PM
Benny Hinn's Avatar
Default Re: Power Enterprise belt too loose...... (rathead)
wrong belt?
Old Aug 10, 2003 | 06:24 PM
rathead's Avatar
Default Re: Power Enterprise belt too loose...... (Benny Hinn)
there is only one b-series PE belt
Old Aug 10, 2003 | 06:32 PM
justBLZE's Avatar
Chopper 2 Hopper
I'm pretty sure there's B16 belt and a different belt that applies to B18.
Old Aug 10, 2003 | 06:52 PM
b19coupe's Avatar
Default Re: Power Enterprise belt too loose...... (tommySI)
B16 and B18 are two different belts, so the wrong belt is a possibility.
Old Aug 10, 2003 | 07:17 PM
Suprdave's Avatar
Default Re: Power Enterprise belt too loose...... (b19coupe)
Nah, those belts stretch out...tried re-using one that had low miles and the belt wouldnt tension enough.
Suprdave
Old Aug 10, 2003 | 08:23 PM
ArinX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rathead &raquo;</TD></TR><TR><TD CLASS="quote">there is only one b-series PE belt</TD></TR></TABLE>
there is def 2 diff belts for b16a apps and b18 apps
Old Aug 10, 2003 | 08:38 PM
rathead's Avatar
Default Re: Power Enterprise belt too loose...... (ArinX)
i thought there was only one, sorry
Old Aug 10, 2003 | 10:01 PM
b20ek's Avatar
Default Re: Power Enterprise belt too loose...... (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">Nah, those belts stretch out...tried re-using one that had low miles and the belt wouldnt tension enough.
Suprdave</TD></TR></TABLE>
Would you recommend OEM over a PE belt?
Old Aug 11, 2003 | 09:56 AM
Default Re: Power Enterprise belt too loose...... (b20ek)
I figured out the problem... wrong water pump was used
It's a DART block with B18C PE belt and it WAS an LS water pump... I've since changed it to a VTEC (ITR/GSR) water pump
Old Aug 11, 2003 | 01:40 PM
Suprdave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20ek &raquo;</TD></TR><TR><TD CLASS="quote">
Would you recommend OEM over a PE belt?</TD></TR></TABLE>
Ofcourse, unless your runnin da big cams...(Toda B\C\D)
Or anything with a large primary lobe.
PM me for a price on either...PE or TODA.
Suprdave
Old Oct 1, 2003 | 11:38 PM
importbeat's Avatar
PE actually has 3 different B series engine sizes!
http://www.power-enterprise.net
Old Oct 2, 2003 | 06:31 AM
Drag R's Avatar
Default Re: Power Enterprise belt too loose...... (importbeat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importbeat &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.power-enterprise.net</TD></TR></TABLE>
i see only 2.....
Old Oct 3, 2003 | 05:50 PM
importbeat's Avatar
Default Re: Power Enterprise belt too loose...... (Drag R)
RB Motoring has 3 different part numbers all in stock (I checked for you today):
BH111 (B18C)
BH121 (B16A)
BH221 (B20B)
Old Oct 3, 2003 | 06:48 PM
Enrikez's Avatar
DO NOT USE OEM BELT WITH TODA"S.....the teeth will fly right off.
even with the PE belt i will be changing it every 15-18,000 miles.
I still constantly check it like 2wice a week.
Old Oct 3, 2003 | 07:40 PM
SuperTwinz's Avatar
Default Re: Power Enterprise belt too loose...... (1meanB18c5civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1meanB18c5civic &raquo;</TD></TR><TR><TD CLASS="quote">DO NOT USE OEM BELT WITH TODA"S.....the teeth will fly right off.
</TD></TR></TABLE>Then you must be doing something wrong.
Old Oct 3, 2003 | 07:43 PM
Enrikez's Avatar
Default Re: Power Enterprise belt too loose...... (SuperTwinz)
yeah, thats what it is..i have no idea what i'm doing.
Old Oct 3, 2003 | 09:00 PM
notsure's Avatar
cmon then, tell us how good a toda tbelt is, us it so dif then a oem belt, what is different about it, is it the toda cam gears? then what is it? is it me being wasted and hostile, yes it is!! if you have toda B's or lower, fuyck toda, use oem
Old Oct 3, 2003 | 09:09 PM
Enrikez's Avatar
Default Re: Power Enterprise belt too loose...... (notsure)
I didnt say the Toda or PE timing belt is the worlds best timing belt!!!!!!
but with Toda's(B's), youre gonna strip that belt if its OEM. if you havent , your lucky.
i have B's, i know lots of posters and people who have stripped their timing belts because of the B's.
i don't get hostile on the net guy. so relax. do what you want. its your motor, i dont give a ****. if i have the cash to buy a $150 belt ..hey thats me not you...so dont worry about it. chill.
vinceiscoo
Sep 16, 2008 11:20 PM
kenny24
Aug 30, 2005 03:52 AM
99bb6
21
Oct 2, 2004 08:23 AM
chads
Jan 9, 2004 10:42 AM
patdemps
Jul 2, 2003 06:25 PM
