ls clutch
Old Aug 10, 2003 | 01:50 PM
S13 slide's Avatar
Default ls clutch
would a clutch that fits my cable ls tranny, work on a cable b16 tranny or cable B17 tranny? thanks
Old Aug 10, 2003 | 02:36 PM
S13 slide's Avatar
Default Re: ls clutch (S13 slide)
kewl, are the mount points teh same also? or do i need another mount kit? i have the old school hasport. thanks
Hondasaurs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S13 slide &raquo;</TD></TR><TR><TD CLASS="quote">would a clutch that fits my cable ls tranny, work on a cable b16 tranny or cable B17 tranny? thanks</TD></TR></TABLE>
No. The shaft that lins up with flywheel is slightly larger on the B16/B17.
Sorry for the wrong info before. I thought you were talking about the clutch cable.
Old Aug 10, 2003 | 02:37 PM
Hondasaurs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S13 slide &raquo;</TD></TR><TR><TD CLASS="quote">kewl, are the mount points teh same also? or do i need another mount kit? i have the old school hasport. thanks</TD></TR></TABLE>
The mounts will remain the same.
Old Aug 10, 2003 | 04:33 PM
zCivic's Avatar
Default Re: ls clutch (Hondasaurs)
It depends on what model tranny it is. Some B16's use a smaller imput shaft and some don't. As for the 92-93 GS-R it uses the large input shaft. Both use the same mounts as before. In that aspect all cable B series use the same mounts
xmattx
Jul 28, 2009 01:11 PM
car91481
Oct 3, 2007 02:44 PM
luvs2spooge
Aug 31, 2007 06:34 AM
JDMracer17
Nov 9, 2005 08:33 PM
HamiltonRex
Dec 23, 2004 04:33 PM
