Kyokugen Lug Nuts
Old Aug 10, 2003 | 10:42 AM
PSU's Avatar
PSU
formerly DxHatchback
Default Kyokugen Lug Nuts
after hearing all the horror stories of them stripping, im reconsidering ordering them.
what do you guys think?
which is better? open or closed end?
Old Aug 10, 2003 | 10:44 AM
WHATS VTEC's Avatar
Default Re: Kyokugen Lug Nuts (DxHatchback)
i think open looks a lot cleaner..
Old Aug 10, 2003 | 11:03 AM
UnrealSpeed's Avatar
I had them, on my old coupe which was stripped a while back. They saved my rims cuz they stripped! Ah, I wont roll them anymore, I had two sets beacuse 6 stripped while getting new tires.
Modified by UnrealSpeed at 8:22 PM 8/10/2003
Old Aug 10, 2003 | 11:15 AM
PSU's Avatar
PSU
Default Re: Kyokugen Lug Nuts (UnrealSpeed)
seems like they strip on everyone
Old Aug 10, 2003 | 11:16 AM
ZEAL-SPORTS's Avatar
I have had mine for like three years, and have not yet had a problem with them... nock on wood! No, but I also heard that the new Koyo's have a new key that will not strip out your lugs, because the key is now made from a much stronger material and it is still light weight. I have the black open ends, and as long as you do not have a shop use an air gun on them then you should be fine, and you shouldn't use an air gun on any after market lug nut... it messes them up in time. ;}
Old Aug 10, 2003 | 11:29 AM
PSU's Avatar
PSU
Default Re: (ZEAL-SPORTS)
check your IM <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZEAL-SPORTS &raquo;</TD></TR><TR><TD CLASS="quote">I have had mine for like three years, and have not yet had a problem with them... nock on wood! No, but I also heard that the new Koyo's have a new key that will not strip out your lugs, because the key is now made from a much stronger material and it is still light weight. I have the black open ends, and as long as you do not have a shop use an air gun on them then you should be fine, and you shouldn't use an air gun on any after market lug nut... it messes them up in time. ;}</TD></TR></TABLE>
Old Aug 10, 2003 | 11:37 AM
EG*MonKEY's Avatar
Default Re: (DxHatchback)
get a allen key tool set from snap on........then u wont have to worry about the cheapo nuts...if not get what i got.......
Old Aug 10, 2003 | 11:43 AM
PSU's Avatar
PSU
Default Re: (EG*MonKEY)
are they Rays? if so, F you.
wish i had the $$$ for them
FF-sean's Avatar
kyokugen
volk lugs is the way to go
Old Aug 10, 2003 | 11:45 AM
allmtr's Avatar
Default Re: (ReaL JDM Eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReaL JDM Eg6 &raquo;</TD></TR><TR><TD CLASS="quote">kyokugen
volk lugs is the way to go </TD></TR></TABLE>
Old Aug 10, 2003 | 11:50 AM
built562's Avatar
Default Re: (allmtr y0!)
i have had mie for quite some time, just lube the wheel studs with wd-40 every now and then and no lug nut will strip, and dont use an air gun.
Old Aug 10, 2003 | 11:51 AM
PSU's Avatar
PSU
$130 shipped
$52 shipped
Old Aug 10, 2003 | 11:53 AM
sckhatch's Avatar
Default Re: (akumaracer)
mine work fine
Old Aug 10, 2003 | 11:56 AM
PSU's Avatar
PSU
Default Re: (sckhatch)
if you have kyokugens, post pictures please
Old Aug 10, 2003 | 11:57 AM
Here is a pic that u requested Mr. DxHatchBack
Old Aug 10, 2003 | 12:01 PM
crazy eyez killa
Guest
Posts: n/a
I used to have those, until a mechanic managed to strip some with an air gun!
Old Aug 10, 2003 | 12:02 PM
PSU's Avatar
PSU
thanks mr. zeal
Old Aug 10, 2003 | 12:12 PM
piscorpio's Avatar
I've had no problems with mine, almost 2 years now. Just remember to torque them to Kyokugen's specs, which is 88-110Nm, not 80ft./lbs.
I have been torquing to 90Nm and they've been fine. They are pretty damn light as well, you will swear they are made of plastic or something.
Old Aug 10, 2003 | 12:50 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: Kyokugen Lug Nuts (piscorpio)
Lugs strip because people are morons and don't use 80 - 90 foot pounds to tighten them.. Instead they use an air gun or do it by hand and do it to 200+ ft lbs. This causes the AFTERMARKET, WEIGHT REDUCING lug to strip or causes the key to strip.
What do you think is gonna happen when you get lighter lug nuts? You think they are going to be stronger than your stock ones? Stock lugs are heavy in turn making them strong.
Bottom line is, all aftermarket lugs/keys will strip if not used properly. Some just strip more quickly than others. Instead of investing 100+ bucs on MUGEN lugs that "don't ever strip" try spending 100 bucs on a torque wrench so you can shut the **** up about your lugs/keys stripping.
Old Aug 10, 2003 | 01:03 PM
Moe's Avatar
Moe
Default Re: Kyokugen Lug Nuts (Hatchy-Ownzjo0)
my friend has koyo's and have never had a problem with them, he sitll have the extra 4 from his set, cuz he hasnt stripped one yet.
There 7 point, and you have to use the key to take them off, if you dont your gonna **** something up. Common sense will really keep you from stripping them, that and dont over torque them.
i also have Ray's! WOOT WOOT!!!! Just get over the price and buy the damn things. Its just $$$ dont sweat the petty stuff.
Modified by Moe at 10:35 PM 8/10/2003
Old Aug 10, 2003 | 01:13 PM
JDMb18civic's Avatar
mines stripped...
im using skunks now
Old Aug 10, 2003 | 01:22 PM
mobceo's Avatar
Default Re: (JDMb18civic)
yes thay are junk!!!!!!!!!!!
Old Aug 10, 2003 | 04:40 PM
PSU's Avatar
PSU
i wanted skunks, but they dont lock <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMb18civic &raquo;</TD></TR><TR><TD CLASS="quote">mines stripped...
im using skunks now</TD></TR></TABLE>
Old Aug 10, 2003 | 04:41 PM
Audi RS4's Avatar
Lover
i've had mine forever and nothing has happened to them yet......
**knocking on wood**
Old Aug 10, 2003 | 04:50 PM
esoterEK..'s Avatar
Default Re: Kyokugen Lug Nuts (AK1200)
