poor gas milage.. very poor
Old Aug 9, 2003 | 11:00 PM
JonGP4's Avatar
Default poor gas milage.. very poor
well, i noticed lately i've only been getting like 190 miles per tanks, which is about 20 MPG or so which sucks.. i got this car for the milage which should be in the 30s.. i ran 2 cans of b12 chem cleaner through it and i think it helped, what are signs of sticking injectors and what else could cause this, i already replaced the o2 sensor i thought it helpped for awhile but it didn't.. this is really bothering me i'm gonna throw on the A/F gauge from my accord to see how rich it is running. But please tell me what else to look for
thanks
Old Aug 10, 2003 | 02:05 AM
joelidge's Avatar
Default Re: poor gas milage.. very poor (JonGP4)
Pull the plugs and see what your engine is doing. Do a search on google for reading plugs and you should be able to find the basics. Also check your ignition timing. It could be a number of things but this is where I would start.
Old Aug 10, 2003 | 06:12 AM
JonGP4's Avatar
Default Re: poor gas milage.. very poor (joelidge)
yeah i figured i'd try that, proally just change out the injectors since i have some laying around, i'm really hoping its just a sticking injector, or maybe a stuck FPR i mean, it couldn't be much else. the plugs are fairly new
Old Aug 10, 2003 | 06:39 AM
Camabird's Avatar
wow, you get about same MPG as my V8, lol. How big is your tank? must be pretty small if you only go 190 miles with 20mpg, I get about 250
Old Aug 10, 2003 | 06:54 AM
1990hondaHF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonGP4 &raquo;</TD></TR><TR><TD CLASS="quote">well, i noticed lately i've only been getting like 190 miles per tanks, which is about 20 MPG or so which sucks.. i got this car for the milage which should be in the 30s.. </TD></TR></TABLE>
Low tire pressure, Bad O2, clogged Air filter, using A/C, plugs/wires/cap/rotor gon bad, or any of the other 10 or so sensors might have gone bad....by the way, what car/engine do you have?
Old Aug 10, 2003 | 07:34 AM
Steve90HB's Avatar
Default Re: poor gas milage.. very poor (1990hondaHF)
it could also be the way you drive it, where do you shift at? I noticed when I drive pretty hard to get movin at stop lights my gas milage drops considerably...
Old Aug 10, 2003 | 09:53 PM
JonGP4's Avatar
Default Re: poor gas milage.. very poor (Steve90HB)
the car is an 89 HB d15b2 with the MPFI conversion SI cam shaft, Si ECU from a 90. I drive pretty hard most of the time shifting at 4500 or so.. but i still think the gas milage should be at least high 20s, i havn't driven it in a couple days, due to the weather being hot as hell, and all my trips have been long.. hopefully the fuel injector cleaner worked and it was just a sticking injector?
Old Aug 11, 2003 | 01:09 PM
^jefs0ng's Avatar
Banned
Yeah my gas mileage is close to 20 mpg too even though I shift just after 3 sometimes. I have a jdmb16 in my rex guess I'll try checking what those dudes said.
Old Aug 11, 2003 | 02:42 PM
civickiller's Avatar
Default Re: (jsxtek)
just do a full tune up and see what that does
Old Aug 11, 2003 | 03:30 PM
I8ayellowcrayon's Avatar
Thats the same way with my Isuzu 2.3 carbed. I get 18 mpg most of the time just regular driving. My friends 1500 GMC with a 5.7 in it gets the same mileage.... It's been tuned up and timed back to stock (it was 6* advanced...), new plugs/wires, new dizzy rotor and cap, carb cleaner, new air filter, and it got about 20 for almost a month... Now its back at 18....
Old Aug 11, 2003 | 03:36 PM
mntuner2's Avatar
Check engine compression too. Usually if a car is misfiring a good tune-up fixes the problem. (cap, rotor, plugs, wires, qualtiy o2 sensor) I just got NGK wires and I am suprised at how much of a difference NEW wires can make.
Old Aug 11, 2003 | 03:38 PM
mntuner2's Avatar
toshko321
Oct 18, 2009 07:15 AM
92egcivicls
11
Oct 28, 2008 01:07 AM
4DRmafia
Mar 28, 2005 10:54 PM
.ShawnD.
May 14, 2003 06:16 AM
Buckshot
Nov 7, 2002 08:16 AM
