Tranny internal transferring
Old Aug 9, 2003 | 10:39 AM
Toptul_Honda's Avatar
New User
Default Tranny internal transferring
i have an 88 dx tranny and i know someone with a 89-91 si tranny with a crakced case.
is it possible to transfer all of the components into the 88 case?
Old Aug 9, 2003 | 01:44 PM
silverCRXTC's Avatar
Default Re: Tranny internal transferring (G2-Rex)
should be, what is cracked the inner case (closest to the motor) or outer case, if its the outer u can just pop the case off and slide on your dx and your done, but with the 89-91 the output shaft might be diff size so u might have to change bearings and clutch/flywheel # of splines i believe, (i can remeber)
Old Aug 9, 2003 | 04:48 PM
New User
Default Re: Tranny internal transferring (silverCRXTC)
which bearings are you talking about
Old Aug 9, 2003 | 07:34 PM
I8ayellowcrayon's Avatar
Differential bearings are what he's talking about, I think anyways. The Si bearings are bigger if I remember correctly.... But other than the differential, the DX and Si trannies are the same.
Also, like CRXTC said, if the Si tranny only has cracks on the cover case, then just swap it out with your DX cover. If he was talking about the bearings at the top of the mainshaft, then there's no problem, they are both the same size.
Old Aug 9, 2003 | 10:29 PM
New User
Default Re: (I8ayellowcrayon)
thanks
so everything is interchangeable?
i can use the 89-91 input shaft as well?
Old Aug 9, 2003 | 11:35 PM
USDM 4G VTEC's Avatar
u have a 88 tranny
and u can get a 88-91 tranny Si
on ur case, u cna transfer all the components from the SI case to ur DX case with no problems xcept the differential since the Si diff has a bigger bearings.... u going to have to take the final drive and diff ring gear off the si and put it onto the DX one... (note: remember the diff ring gear its left hand threat) as far as all the gears, they are and are not the same at the same time.... i had a few DX trannies and the countershaft bearing wounldt clear for me....also if u use the mainshaft of the Si tranny then ur clutch wont work since it has a diff spindle count..... u will need a new clutch for that..... as far as what u actually have.... i would just take the final drive off the Si and put it into ur DX one.... the 1-5 gears are the same, .... i have a DX/Si hybrid tranny, that i can help u with any questions u have.... while uhave it open change the diff pin.. ( i am actually making some strong ones..)
Old Aug 10, 2003 | 05:47 AM
Default Re: Tranny internal transferring (USDM 4G VTEC)
yeah what these guys say is correct, i dont remeber all the d series stuff, im im the b's now and im currently changing the housing on a ls tranny (crx too low= cracked ls tranny) also u might wanna replace some syncos while u have it open
kixcrx
Dec 15, 2006 02:18 PM
tblofsky
Apr 10, 2006 06:54 AM
si0385.
Jan 5, 2006 11:38 PM
SPORT INJECTION
Mar 4, 2004 05:59 AM
MixdCrix
Jun 18, 2003 03:02 AM
