HOW TO: Remove ECU pins on harness
Old Aug 9, 2003 | 10:19 AM
skunk2unerz's Avatar
Default HOW TO: Remove ECU pins on harness
I was going through the search today wondering how to remove the pins off the ECU hareness. Well after searching I really did'nt find too much info except one diagram of how the pins were locked in place. I would say it did help me a little. After a bit of trial and error. I thought of another idea. Try a paper clip. After a bit of testing...i finally got it right. It took less than a minute to remove all the pins off the clips. This will also save you money from buying the Honda tool.
First you will need a wire cutter and paper clip (perferably a thick size).
Then you want to straighten one end of the paper clip so that it is straight.
Take the wire cutter and cut the paper clip at an angle so that it will be cut with a sharp edge.
Now that is done. You want to open the ECU plug up so the that pins are easy to remove. Look at the sides of the plugs. You will see tabs to open it up. Open and Flip.
With the tab flipped open. Loooking at it from the front view. You can see the top is opening is larger than the botton.
You want to insert the paper clip (sharp end pointed downward) to point at the clip that is to be removed.
From here you want to hold the wire to remove and push forward towards end where paper clip is. And with the paper clip press against the tab inside the plug and push the paper clip upward and pull on the wires. Easy as 1-2-3... Good Luck!
Here is a diagram from BANDWAGONEER of what that tab to push at looks like. You want to press at where it says 'NEEDLE'.
Modified by skunk2unerz at 11:50 AM 8/9/2003
Old Aug 9, 2003 | 10:40 AM
aira
Guest
Posts: n/a
Default Re: HOW TO: Remove ECU pins on harness (skunk2unerz)
hurry up and finish wiring up your vtec y0! no wonder they call use team BS.
Old Aug 9, 2003 | 10:42 AM
salbaje's Avatar
great info
Old Aug 9, 2003 | 10:45 AM
Who Said's Avatar
thats some good info
Old Aug 9, 2003 | 11:40 AM
acuracing's Avatar
Nice info.
Old Aug 9, 2003 | 12:49 PM
smnowell's Avatar
Default Re: HOW TO: Remove ECU pins on harness (acuracing)
I usually just open up the connector and pull on the wire until the wire and pin come out. I know it isn't as fancy or technical/correct as your method, but it works for me
Old Aug 9, 2003 | 02:29 PM
stockegsix's Avatar
i was just repinning my harness pinouts, i had no idea how to get them out, i came across this thread and got the pin out in less than a minute. thanks for the info
Old Aug 9, 2003 | 03:35 PM
p10hlm's Avatar
Default Re: HOW TO: Remove ECU pins on harness (zzZZzzleeperCX)
great info
Old Aug 10, 2003 | 05:47 PM
SPOON_EG6's Avatar
gOOd shiet......
Old Aug 10, 2003 | 05:56 PM
cinq's Avatar
I wasted my $6 dental pick for that job. Bummer..
Old Aug 10, 2003 | 07:41 PM
fsck3r's Avatar
Want to send me 2 ecu pins? I need them to wire my ECU for VTEC but I cant find them anywhere!!
Old Aug 10, 2003 | 07:44 PM
SPOON_EG6's Avatar
Default Re: HOW TO: Remove ECU pins on harness (fsck3r)
sure...35cents for postage and handling.....
Old Aug 10, 2003 | 07:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fsck3r &raquo;</TD></TR><TR><TD CLASS="quote">Want to send me 2 ecu pins? I need them to wire my ECU for VTEC but I cant find them anywhere!!</TD></TR></TABLE>
IM me your address and ill send it by snail mail. I got alot of pins to spare.
Old Aug 10, 2003 | 09:34 PM
Team 4's Avatar
Have a friend who works at the dealership and get them to borrow the OEM pin kit.
Old Aug 10, 2003 | 11:14 PM
TCLchicago1's Avatar
thnx for the heads up man..........
Old Aug 10, 2003 | 11:38 PM
elwood's Avatar
Always nice to have a pile of wiring harnesses to cut up.
Old Aug 17, 2003 | 05:56 PM
bump incase someone else needs to read.
Old Aug 17, 2003 | 08:39 PM
Team 4's Avatar
Default Re: (TCLchicago1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TCLchicago1 &raquo;</TD></TR><TR><TD CLASS="quote">thnx for the heads up man..........</TD></TR></TABLE>
No problem!
Old Aug 17, 2003 | 08:52 PM
EK MONEY's Avatar
Default Re: (REVHARD_EF)
i just open that top peice and yank!
Old Aug 18, 2003 | 03:47 PM
GRAVEDIGGER's Avatar
Default Re: (Peagreenhatch)
i looked at my ecu plugs and not all of them open up like in your picture. so do you do the same thing just without the plug open?
Old Jan 21, 2004 | 11:07 AM
TheOne's Avatar
Default Re: (GRAVEDIGGER)
uh yeah, my plug dosn't open up, what then.
Old Jan 21, 2004 | 11:09 AM
Ricey McRicerton's Avatar
Default Re: (TheOne)
Don't forget to put this in the FAQ thread at the top of the page. Nice writeup!
Old Jan 21, 2004 | 11:20 AM
H22A EG6's Avatar
Default Re: (Ricey McRicerton)
yea good ****
Old Oct 13, 2004 | 03:03 PM
HeikDiesel's Avatar
Default Re: (H22A EG6)
old bump....can I get the pics to work again?
Old Oct 13, 2004 | 03:06 PM
Milano_EH3's Avatar
Default Re: (PhatAcuraIntegra)
It's not hard to do...in fact I used a small hex precision tool from a Radio Shack kit of small screwdrivers and hexdrivers. You can see what I did if you look at the "JDM folding mirror install" in the tech section of my homepage.
