200 whp
Old Aug 9, 2003 | 09:53 AM
KRiS1's Avatar
Default 200 whp
What do I need to do to get there? I have a 01 B18C5 in my 94 hatch. I have a general idea, Im just not sure of where to start.
Old Aug 9, 2003 | 11:08 AM
Casey's Avatar
Default Re: 200 whp (POS Hatchback)
intake, good header(sms, hytech, headertech), good exaust(sms or hytech) or no exaust, hondata, mild cams, and a little more compressiong, and tuning should be a good start
Old Aug 9, 2003 | 11:22 AM
KRiS1's Avatar
What will my comp be with .20 over CTR pistons?
Old Aug 9, 2003 | 11:27 AM
Casey's Avatar
high, despite what c-speedracing says. itll be in the 12.3-12.6 range with just the pistons
Old Aug 9, 2003 | 12:05 PM
Rob Dizzle's Avatar
Default Re: 200 whp (Casey)
you can hit it with the cams you still have.
-jdm itr pistons or cp pistons
-stock or aftermarket rods
-sell itr head and get a gsr and have it ported and polished
-itr valves
-stiffer valve springs
-310 injectors
-honda s200 with 2 hours of tuning done by a good tuner
-a good header (no mass produced ****)
find a good engine builder who has built multiple high hp efficient motors.
if a crappy builder/tuner does work on the engine, you might have to spend another 2k to get the motor to 200whp
Old Aug 9, 2003 | 12:26 PM
LSiTurbo's Avatar
Default Re: 200 whp (Bob-DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">you can hit it with the cams you still have.
-itr valves
-310 injectors
if a crappy builder/tuner does work on the engine, you might have to spend another 2k to get the motor to 200whp </TD></TR></TABLE>Thats alot of chit for 200 HP.
Old Aug 11, 2003 | 09:07 AM
KRiS1's Avatar
Anyone else?
Old Aug 11, 2003 | 09:37 AM
NW94RS
Guest
Posts: n/a
-hondata s200(good socal tuner ) $?
-jdm itr pistons $300
-jdm ctr camshafts w/ toda gears $400/400
-j's racing intake $300
-smsp header/exhaust $900-$1000
-portflow head $900
-port matched i/m t/b $300
-new bearings/seals/gaskets $200
prices may be subject to change
Old Aug 11, 2003 | 09:40 AM
All Motor Rex's Avatar
Good bolt ons and a ported & polished head w/ vafc should be able to make 200whp. Stock ITR cams & pistons will work, you can run a single layer head gasket to get a little more compression. I was running a similair setup and it made 202whp.
Good Luck
Old Aug 11, 2003 | 11:21 AM
skribblah's Avatar
Default Re: 200 whp (All Motor Rex)
SMS header
stock ITR intake box & arm
CTR intake cam or s2s2
good 2.5" exhaust
hondata
a better p&p job wouldnet hurt...
Old Aug 11, 2003 | 12:05 PM
integran1's Avatar
headers(hytech, toda), intake(comptech, spoon drop in) dyno tuning with v-afc, some cam gears, hondata s200, stiffer rods, higher compression, advanced timing..etc
Old Aug 11, 2003 | 12:06 PM
KRiS1's Avatar
Should I go CTR pistons or just use a thinner headgasket or mill the head?
Old Aug 11, 2003 | 12:18 PM
rodimus's Avatar
instead of selling the itr head and getting a gsr head ported and polished...
wouldn't it be better to keep an itr head and get the chambers welded and
reshaped to the pentroof style, which is used in the gsr and rsx (dc5) heads?
unless the gsr has a superior intake manifold...
Old Aug 11, 2003 | 12:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POS Hatchback &raquo;</TD></TR><TR><TD CLASS="quote">Should I go CTR pistons or just use a thinner headgasket or mill the head?</TD></TR></TABLE>
Depends how much money you want to spend. Cheaper to run a thinner head gasket or mill the head. You don't need that much compression to reach 200whp
Old Aug 11, 2003 | 03:25 PM
Charlie Moua's Avatar
Well you'll have to ask your self ....if you want the simplest and fastest way to get 200whp or the overall best way of doing it.
This is what i personally would do if I was on a small budget and all i wanted was 200whp....no more no less:
*B18c1
*EF-1 JUN killer cams...or jun3
*valve train upgrade (jun, toda, REV, crower, )
*really good headers (SMSP, Jun, Hytech, IB modded JG headers, AN-R,
Erickracing)... I like what the other guy said.. none of that mass production *****.
afc
fpr
cam gears
some chepo head work shave head a little
stock 240cc injectors will be fine
cai
CTR oversized pistons
....... that should be enough to get you to you 200 whp goal.
now for a better more complete setup that will ensure you more room to grow. I personally would go with:
-B18c1
-Sleeved out to 85mm
-IB weisco 85mm 11.8 to 12.5cr
-CTR cams
-toda cam gears
-high flowing headers and exhust
-ITR overbored TB 65mm ''ish
-CAI
-FPR
-hondata tunning... maybe 3 to 5 runs.... 30 minutes of tunning
-RC 310cc injectors
-apr head bolts!!!
NOW that should get you to 200whp. Notice that you haven't even touched the head yet and you have very mild street OEM cams that you can keep you stock valvetrain..... you still have plenty of more room to make power.
just my thoughs.... good luck
BTW getting a 200whp B18c5 should be a walk in the park..not very hard to do at all.
Old Aug 11, 2003 | 03:30 PM
KRiS1's Avatar
Default Re: 200 whp (Charlie Moua)
B18c1?
I'm assuming you are referring to the head?
I don't plan to ditch the C5 already in my car
I think I'm just going to get the .25 over CTR pistons, SMSP headers & exhaust, and hondata and see where I stand at that point
Old Aug 11, 2003 | 06:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POS Hatchback &raquo;</TD></TR><TR><TD CLASS="quote">B18c1?
I think I'm just going to get the .25 over CTR pistons, SMSP headers & exhaust, and hondata and see where I stand at that point</TD></TR></TABLE>
yeah don't ditch the c5 head... (you'll kick yourself in the nuts later if you do )
Good list of mods. you should see about atleast 15whp gains
Old Aug 13, 2003 | 05:14 PM
topspeed86's Avatar
Why do you say sell the ITR head and go with GSR. I've heard that before maybe you can explain it because of the design of the combustion chamber.
Old Aug 13, 2003 | 05:19 PM
rodimus's Avatar
Default Re: 200 whp (topspeed86)
scroll up and read my previous post
Old Aug 13, 2003 | 05:23 PM
topspeed86's Avatar
Default Re: 200 whp (EVOL)
read your post and whats your opinion on the ITR Vs. GSR Head
Old Aug 13, 2003 | 06:07 PM
rodimus's Avatar
i would ask rocket on this board..jeff from IB..he's banned , MAX_CFM ...
also look at the threads i started here in the all motor forum..
others can explain better than i can.
IMO if u have the itr or b16 head just get the chambers rewelded and reshaped
to the pentroof style that's like the rsx and the gsr heads...
but i'm not sure how the IM from the ITR vs. GSR stacks up...
DC5ftmfw
11
May 1, 2006 08:05 PM
Infamous
Apr 30, 2004 04:40 PM
bocian
Oct 30, 2002 02:11 PM
01PYITR
Aug 17, 2002 05:32 PM
guyuenvy
Mar 5, 2002 12:19 PM
