crx hvac controls question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thekori »</TD></TR><TR><TD CLASS="quote">i have an 88 crx si and the hvac controls are all cracked and broken. is it possible to use some from a hf or dx? or even a civic?</TD></TR></TABLE>
ALL 2G CRX hvac controls are the same and will swap n/p.
The civics I believe are cable actuated and are not swapable. The CRX controls are electric/servo operated and the civics are NOT.
Get some confirmation though 1st.
HTH
HTH
You could use a civic climate control panel, but you would have to remove the servos from the crx hvac system. Try to get a crx one if you possibly can, it will be much eaiser to deal with.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thekori »</TD></TR><TR><TD CLASS="quote">i think i'd rather use the manual hvac control from the civic...how hard is it to swap that in?</TD></TR></TABLE>
I wouldn't know where to begin. I guess you'll need to remove the servos and the elertrical connectors. Then find a way to jerry-rig the actuator levers and then get the civic actuator cables and find a way to attach them to your home made levers.LOL Make sure you don't remove the connectors and wires for the nightime illumination though. LOL
Good Luck.
HTH
Good Luck.
HTH
B-serious
11
Jul 26, 2006 08:55 AM
BOSS-REX
Jan 28, 2005 08:24 PM
