Del Sol Digital Clock
Old Aug 9, 2003 | 09:22 AM
tim120's Avatar
Default Del Sol Digital Clock
I have a 93 del Sol and for those who know anything about them the digital clock is to the left of the gauges. My clock is so dim/unlit that you can only see it at night and even then you can barely see it. Im guessing it has somthing to do with the connection but if anyone has had this problem or has any ideas please reply. Any advice would be great. Thanks
Old Aug 9, 2003 | 10:55 AM
Russ713's Avatar
dAng!
Default Re: Del Sol Digital Clock (tim120)
I dont know about your problem, but if you need one, i have one you can buy if you need to.
Old Aug 9, 2003 | 08:14 PM
tim120's Avatar
i think i might go into it tomarow and see if i can see anything wrong but any advice would be good
Old Aug 9, 2003 | 10:07 PM
vulgar_si's Avatar
Is it really dim when the headlights are on, or when they are off? On my 93 del sol si the clock is very bright until you turn the headlights on, then it gets a little bit dimmer. Hope that helps.
Old Aug 9, 2003 | 11:00 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: Del Sol Digital Clock (vulgar_si)
take your gauge cluster out and check all the plugs. if you turn on your headlights during the day you probably won't be able to see your digital clock at all. they're nice and bright, and once you hit the headlights they dim down.
Old Aug 10, 2003 | 12:44 AM
EG2 SiR's Avatar
Default Re: Del Sol Digital Clock (AzntaggeR)
I hate to say it.....but......Have you checked the dimmer ****?
Old Aug 10, 2003 | 05:14 AM
stevecockrill's Avatar
Default Re: Del Sol Digital Clock (EG2 SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR &raquo;</TD></TR><TR><TD CLASS="quote">I hate to say it.....but......Have you checked the dimmer ****?</TD></TR></TABLE>
Old Aug 10, 2003 | 10:07 AM
tim120's Avatar
I Have checked the dimmer light lol. Its not the headlights ether you cant even see the clock during the day. At night you can see it just barely when the headlights arent on so it has to be somthing behind the gauges.
SammyG
Aug 15, 2009 11:50 AM
delsol10psi
Nov 1, 2004 08:17 PM
dohcredsol
Jul 15, 2004 06:51 PM
