Spark plug Recommandation and GAP for High Compression Motors..
Hey...
I would like to know the best plug with low resistance wires, and MSD Coil and Multi Spark Box, along with the proper Gap...
thanks
thanks
Well Rocket's plugs gapped to .035" seem to work out nicely. However something like NGK BKR6E-11 gapped to the standard 1.1mm or .043" will work as well.
i use BOSCH 4227 dyno tested at IB and makes power, also made more power on my motor compared to stock.
Gap is .035
change them ever oil change cuz they are cheap $1.99 each.
Gap is .035
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fox297 »</TD></TR><TR><TD CLASS="quote">Would iridium plugs perform better in high compression engine?</TD></TR></TABLE>
would they? I wanna know to
Way over-rated. Don't waste your money on exotic spark plug material.
Go NGK or Autolites in the proper heat range and you'll be cool.
Also don't gap more than 0.038 for NA and not more than 0.024 for FI.
Is it better to regap plugs to a smaller gap. I think OEM is .044" and i forgot what the NX tech guy told me but I think it was .030 " gap. I am tring to confirm this. I have nitrous in my integra LS. The plugs i'm going with are ZFR7F-11 which are two steps colder than stock. What does making the gap smaller do anyways
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninja8oi »</TD></TR><TR><TD CLASS="quote">Is it better to regap plugs to a smaller gap. I think OEM is .044" and i forgot what the NX tech guy told me but I think it was .030 " gap. I am tring to confirm this. I have nitrous in my integra LS. The plugs i'm going with are ZFR7F-11 which are two steps colder than stock. What does making the gap smaller do anyways</TD></TR></TABLE>
smaller is usually better especially for Nitrous or FI.
copper is the best material for spark plugs usally. All those fancy ones are just designed to last longer, but since we are not ricers we don't care about length before replacement. I'll be running coppers untill they make artifical spark plugs from some sort of electrocharged plastic.
arent you supposed to run the highest gap possible unless your misfiring up top, then you go ahead and lower the gap setting. correct?
Oh and if you want Iridium then go with NGK BKR7EIX-11 which are only around $6.50 each at http://www.clubplug.net/index.html
89si-rex
33
Oct 9, 2013 11:20 AM
Power Rev Racing
Jul 20, 2005 09:08 PM
