DC's and EG's with lenso's ????
Old Aug 8, 2003 | 10:14 PM
J2turbo21's Avatar
Default DC's and EG's with lenso's ????
OK i just got my lenso's on and i got coilovers,well the steering knuckle is rubbing on the inner part of my driver side tire and on the passenger side it has less then a finger width of space between them.Is anyone else having this problem?Im using 22x8x13 M&H with 13" lenso's,i set the tire pressure at 15psi just to see what they look like on the car.
I heard with lenso's there is no need for spacers or longer wheel studs and whatever else that you need if you run Bogarts.
Old Aug 8, 2003 | 10:44 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: DC's and EG's with lenso's ???? (J2turbo21)
i needed a spacer on my 25x8.7x13's on my ek. i thought they bolted right up but they needed a spacer also no matter where i set the coilovers.
Old Aug 8, 2003 | 10:45 PM
J2turbo21's Avatar
Default Re: DC's and EG's with lenso's ???? (MotorMatrix.com)
Did it rub on both sides?Cause mine rubs only on the driver side,also where do i get these spacers from?
Old Aug 8, 2003 | 10:55 PM
I am a bad person
i am not sure if it was both. the first time i fitted them was at the track and i dropped the car down and they rubbed on one side for sure so i jacked it back up and bought some spacers at the track.
Old Aug 8, 2003 | 10:56 PM
J2turbo21's Avatar
Damn i doubt my track sells spacers.
Old Aug 8, 2003 | 11:48 PM
hybridreams's Avatar
I was told Pep Boys has spacers.
Old Aug 9, 2003 | 08:37 AM
thegrinch's Avatar
I use the same thing with no problems.
What year is the car?
Old Aug 9, 2003 | 02:26 PM
J2turbo21's Avatar
Default Re: DC's and EG's with lenso's ???? (thegrinch)
Its a 92 civic hb,someone told me it could possible be bent but i dont know how since i never been into an accident with the car.Also i ran a car back and its never been in an accident.
Old Aug 9, 2003 | 03:30 PM
tygsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 &raquo;</TD></TR><TR><TD CLASS="quote">OK i just got my lenso's on and i got coilovers,well the steering knuckle is rubbing on the inner part of my driver side tire and on the passenger side it has less then a finger width of space between them.Is anyone else having this problem?Im using 22x8x13 M&H with 13" lenso's,i set the tire pressure at 15psi just to see what they look like on the car.
I heard with lenso's there is no need for spacers or longer wheel studs and whatever else that you need if you run Bogarts.</TD></TR></TABLE>
My lenso's fit perfect on my dc2 with ground controls. though I had to jack the suspension all the way up to fit the 24.5's..
Old Aug 9, 2003 | 04:26 PM
thegrinch's Avatar
Default Re: DC's and EG's with lenso's ???? (tygsr)
no problem here either. Is it rubbing on the caliper or the contol arm?
Old Aug 9, 2003 | 04:39 PM
J2turbo21's Avatar
Its not rubbing the caliper its rubbing ths bar the caliper/rotor are bolted up to.I think its called the knuckle.It bolts to the LCA and the Upper A-arms.
BB6-213
Mar 26, 2011 05:26 PM
CHEETAH
Sep 21, 2010 07:49 PM
turboaap
Sep 30, 2008 12:39 PM
BlackOnBlackTeggie
15
Dec 27, 2004 11:08 AM
AB16A2T
14
May 26, 2003 08:42 PM
