Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
KYB AGX SETTINGS for 93 Civic Coupe
Old Aug 8, 2003 | 09:26 PM
Jdm93civic's Avatar
Default KYB AGX SETTINGS for 93 Civic Coupe
Hi all i just purchased kyb agx's for my civic and i was wondering what settings do use.........what are the recommended settings.........did you feel the recommended settings were to soft or too hard?
Old Aug 9, 2003 | 06:54 AM
Audipwr1's Avatar
Default Re: KYB AGX SETTINGS for 93 Civic Coupe (Jdm93civic)
setting them into the garbage and buying konis......
i ran them on an integra for a season, full hard up front (4) 3/4 in back (3)
save up for better shocks you will be able to feel a didifference
this is for autocross, if your question is a general setup, please ask it somewhere else
Old Aug 9, 2003 | 07:18 AM
Littleton's Avatar
Default Re: KYB AGX SETTINGS for 93 Civic Coupe (Audipwr1)
Run 4f/4r with spring rates of 350f and 500 r. Any higher spring rate and you will be under dampered.
Old Aug 9, 2003 | 10:58 AM
RangerDan's Avatar
Those are great shocks for that car...sure the more you spend the better the performance but in some cases your talking a tenth or two.
What spring rates are you running?
I run 330f/400r and on most courses I set the agx's to 1 in front and 3 in back. I like to have the back end kinda loose and during fun runs I'll go 4 in the backs and get that rear end swinging around in the corners just for the fun of it.
I have a 93 hatch and my buddy has a 95 coupe, he runs 1front 4rear.
Stay with the agx's for now and if you feel the need to move up to a better shock the koni yellows are good but dont stop there look into the tein full coilover set-up as well.
Have fun and play with those settings. BTW on the street I run 1front and 2 rear.
Old Aug 9, 2003 | 11:07 AM
Jdm93civic's Avatar
Thanks guys for all your help.........i have GC coilovers
Old Aug 9, 2003 | 11:27 AM
RangerDan's Avatar
Default Re: (Jdm93civic)
GC's are nice however the stock spring rates are kinda soft. After listening to all the hype I bought a set and instantly started missing my Matrix coilover set-up (yeah currently I'm the only Matrix Advocate in existence)
After talking with dale at gc and .RJ here on h-t I went with the current set up and it feels a lot better...pretty much gonna keep this set up until I go with either yellows or the Tein set-up.
If you call and ask for advice from gc be prepared however they are pretty opinionated.
Old Aug 9, 2003 | 08:54 PM
hondapwr's Avatar
I run 3/4 up front and 7/8 in the rear. I also have Eibach prokit springs and a 22mm ITR rear anti-sway bar with poly bushings. The setup gives me good turn in with mild oversteer depending on tire pressure.
da1lydr1ver
Honda Civic (2001 - 2005)
16
Mar 22, 2014 03:43 PM
driveslow
Mar 11, 2009 02:02 PM
tvrsir
Jun 23, 2005 10:44 AM
FrostyDC4
Jun 25, 2003 03:12 PM
solo-x
12
Nov 27, 2002 08:57 PM
