will 94-01 integra seats fir in my 90 civic SI??
just wondering i can get a set for cheap,,
will it bolt in without a prob??
or what will i have to do to make it fit
im talking bout the front and back seats from a 2 door integra
any help is great
thanks mike
any help is great
thanks mike
they will fit...but you will need to do the following:
for the two most front mounts (re-drill them to a larger size)
rear outer mount (closest to the door) will also need to be redrilled to a larger hole
inner (flat mount hole) will need to be either cut out with a dremel (since it will need to be moved out and enlarged
also for the fronts get some washers so they fill the holes....
rear folding seats will work, the bottom too but there is a gab and the cushn will need to have the metal bracket bend out
i guess this is pretty simple???
i guess ill just hae to take the seats out,,and go from there
thanks for the tips,,it doesnt sound too hard
is it easier to unbolt the whole civic stock seat,,then take off the braket,,and mount it to the teg seat???
or should i just take the civic seat off the mounting braket,,while still in the car??
so basicly,,im just gonna have to make some holes bigger,,and use some washers...and bend the metal braket that holes the back seat??
is it the metal braket that lets the seats fold down??
thanks mike
thanks mike
liyan1430
Apr 30, 2014 02:56 PM
Sleeper180sx
Apr 20, 2004 07:04 PM
Hondasaurs
Jan 31, 2003 08:05 AM
dontcare61776
Jun 15, 2002 10:48 AM
