CRX CRANK ANGLE SENSOR! HELP!!!
Old Aug 8, 2003 | 01:51 PM
Acid832's Avatar
Default CRX CRANK ANGLE SENSOR! HELP!!!
i swaped out my 89 crx si engine with a ZC motor and i put in a 89 integra computer , the car dose not go past 3200 rpm and it is flashing a code 4 wich is the crank angle sensor , my pal previously told me i had to rewire the sensor and i would like to know how and what aire is it and where it need to go?
Old Aug 8, 2003 | 02:15 PM
ThatRicerDaniel's Avatar
Default Re: CRX CRANK ANGLE SENSOR! HELP!!! (Acid832)
somthin in the dizzy department
Old Aug 8, 2003 | 04:07 PM
Blaze45's Avatar
Brrraaaap!
Default Re: CRX CRANK ANGLE SENSOR! HELP!!! (NitrousDreamz)
There is a special sensor on the ZCs that is on the EXH cam on the dizzy side of the engine. This is your CAS. You nee to wire that up to the correct ECU pins on the ECU> do a search and find the write up that Kenji wrote about, he has the info on the ZC wiring. The reason why your car wont rev past 3200 is cause it is in limp mode. Untill you fix the CAS issue, thats how it will stay.... Be sure to reset the ECU after you make the wiring changes.
Blaze
Old Aug 8, 2003 | 05:13 PM
bluecrxsi's Avatar
exactly i got rid of all my zc info after i got my b16,but i remember one or two changes had to be made at the dizzy to have everything right. go to google and put in ZC SWAPS
EF'n
Feb 17, 2008 07:37 PM
Phils
Feb 28, 2007 03:07 PM
-[sphEre]-
13
Oct 14, 2004 08:08 PM
ZColeon
Jun 27, 2002 04:40 PM
crxgurlllll
13
Feb 12, 2002 07:11 AM
