camber in front but not back?
Heres what happened I cut my springs on my 92 cx..(waiting for my H&Rs) I pulled off the front struts to cut my springs when I put them back theres was too much camber but 4 the back I cut them with the strut on and theres no camber problem.. Should I pull off the strut and try 2 straighten it out?....thanks
Get an alignment....cutting your springs is
. The only thing I can tell you is it is normal for the front to have more camber than the rear when the car is lowered.
I would have waited ! in the mean time go buy a camber kit,
guessing the reason you have more NEGITIVE camber in the front is because there is more weight up there ..
allmotorEG-SI
Jun 12, 2003 12:00 PM
