exhaust question?
Old Aug 8, 2003 | 06:33 AM
Hella Flush Kevin's Avatar
Ignore me . . .
Default exhaust question?
I am new to so do not feel like you are wasting your time I want to learn as much as possible. I know that putting duel exhaust on a 1 exhaust car will not let the car performe to its desired performance....civics, preludes, integras. I was wondering how does this compare to a in line 6? 03 accord? I assume that it is a 6 cylinder it needs to get rid of exhaust fumes quicker because it is sucking in more air thus having 2 main pipes connected directly to the cat?
Old Aug 8, 2003 | 06:42 AM
Padawan's Avatar
Darth ModerVader
Default Re: exhaust question? (myspacebarisbroken)
The Accord is a V6, not an I6, so dual exhaust in that application would be benificial.
Old Aug 8, 2003 | 07:47 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: exhaust question? (Padawan)
Precisely.
Old Aug 8, 2003 | 07:54 AM
Ignore me . . .
ok so what is a i6?
Old Aug 8, 2003 | 08:04 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (myspacebarisbroken)
An inline 6. Where a 6-cylinder motor has it's rod/piston combo in a straight line. As oposed to a V6 where there are two cylinder banks and two cylinder heads most common at 90 degrees or 45 degrees to save space. Spit 3 and 3. So you have two separate exhaust manifolds and exhaust. As oposed to the inline 6 which has one exhaust manifold.
Old Aug 8, 2003 | 09:43 AM
Ignore me . . .
ic thanks
jt-sport
Nov 10, 2009 10:52 PM
tekniq
Apr 14, 2009 12:05 PM
Okay20
Aug 23, 2002 11:57 AM
