is it easy to change 5th genth carpet?
Old Aug 7, 2003 | 09:35 PM
im_the_teacher's Avatar
Default is it easy to change 5th genth carpet?
i have tan interior,,,,,,i wonder if i can buy black carpet and swap w/ my current carpet? would it look weird to have 2 different color? anyone done it before ?
before your say anyting about my english....english is my second lange...
Old Aug 7, 2003 | 09:36 PM
aaaallll04's Avatar
Default Re: is it easy to change 5th genth carpet? (im_the_teacher)
yeah, im sure it is rather easy maybe, but black and tan... i dunno about that one
Old Aug 7, 2003 | 09:51 PM
Default Re: is it easy to change 5th genth carpet? (aaaallll04)
oh really,,,,anyone done it before? where you buy the carpet at?
sorry, my interior is like grayish
Old Aug 7, 2003 | 09:53 PM
whoa its len 2's Avatar
taking out the carpet is easy.. just gotta unscrew bolts and screws that hold down the seats and such.. the hardest part i think is taking out the seats and carpet and trying not to scratch your car up.. but yeah its pretty much straight forward.. good luck dood
Old Aug 8, 2003 | 08:15 AM
slow-n-low's Avatar
Default Re: (whoaitslen2)
You may have an interior trim shop in your area (they would recover seats, headliners, dashes etc.) that would have interior carpet for sale. JC Whitney sells precut and molded carpet for Accords. They have color selection and decent price, but not sure about quality though. Black carpet with grey interior would look pretty sweet imo .
Old Aug 8, 2003 | 12:02 PM
stickercuttingcom's Avatar
Swapping carpet is pretty easy. I did it in my 3rd gen. All of the interior has to come out. Seats (of course) all consoles, side plastic on the doors and the side plastic on the pillars. After all of that is out you can pull the OEM carpet out. The carpet you get (mine came from AAuto1.com I think) will be premolded but it wont have the necessary cuts needed to install it. Take your OEM carpet and line it up over the new molded carpet to get a rough estimation on how to put it in. Cut small amounts FIRST. You need to cut enough to get it over the shifter and console things. After you have the general cuts made, you can start cutting larger and larger holes while test fitting the consoles and seats each time. Be careful when taking out th eseats, its pretty easy to bend the rails by setting them down hard. Once a seat rail is bent, good luck on trying to fix it, its not fun.
Other then that, its a very basic install. Honda's come apart quite nicely. Its all phillips head screw heads for the plastic...my 5th gen seems to be the same way also.
Nate.
thedao
Mar 24, 2010 02:15 PM
RA102323
Honda S2000
21
Jul 9, 2009 02:22 PM
dabig1
Apr 6, 2005 12:29 AM
drsues02
May 18, 2002 12:54 AM
