car smoking
Old Aug 7, 2003 | 07:54 PM
IamVtec's Avatar
Default car smoking
My car has been smoking for quite sometime now. It smokes when I crank it and also WOT ( normal driving and badly when I lay on it). I'm not quite sure what is causing it. The color of the smoke is blackish/grey smoke. I'm not really sure if its the PG7 ECU thats causing it (giving it too much fuel).
My car is an HF and I haven't got the chance to get my hands on a PM6, but recently b4 the PG7 I was using the stock HF PM5. But when I go back to install the PM5 car doesn't want to stay on. Any help would be appreciated. TIA.
Its a D16A6 w/PG7
Old Aug 7, 2003 | 08:40 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
Default Re: car smoking (Full Throttle EF)
How many miles on the engine, and how many miles on your Head gasket? You're burning oil there, and if it was gas it'd be black. If you happen to open your head, you'll prolly see **** all over your valves... make certain that this isn't the case before you start swapping electrical supplies.
Old Aug 8, 2003 | 12:45 PM
highhopes's Avatar
Default Re: car smoking (VashTheStampede)
my guess is that oil is getting past your piston rings and into the combustion chamber...how has your oil level been lately? Any slow leaks? Loss of oil could mean that this is the problem.
Old Aug 8, 2003 | 02:24 PM
IamVtec's Avatar
The miles on my motor is unknown. And the oil level has been fine (just got to put some in from the loss from the oil pan gasket) , theres no major oil burned or anything. And the only leaks i have is near the oil pan, and I think that needs a new gasket.
Old Aug 8, 2003 | 02:30 PM
acydphryck's Avatar
Default Re: car smoking (highhopes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highhopes &raquo;</TD></TR><TR><TD CLASS="quote">my guess is that oil is getting past your piston rings and into the combustion chamber...how has your oil level been lately? Any slow leaks? Loss of oil could mean that this is the problem. </TD></TR></TABLE>
BLOW BY ALERT!!! BLOW BY ALERT!!! BLOW BY ALERT!!!...piston rings are shot homie...time to tear her apart and put in new rings...need to hone the cylinders too...
GoodUsername
Mar 9, 2015 04:59 AM
BigZeke5
Nov 11, 2008 07:23 AM
ITLNstallion818
10
May 27, 2007 07:30 PM
EF9 JAMS!!!
Oct 7, 2006 12:37 PM
CivicBoi
May 27, 2002 11:59 AM
