brake caliper rubbing
Old Aug 7, 2003 | 07:19 PM
allaboutgsr's Avatar
Default brake caliper rubbing
so i was driving home today and i came to a light and had to brake kinda hard and i hear this weird sound...when i get home i find out its my brake caliper rubbing against my rim...its like it came off...any idea how this may have happened ? can i jsut take the caliper off and put it back on again ?
Old Aug 7, 2003 | 07:39 PM
KOALA YUMMIES's Avatar
Default Re: brake caliper rubbing (allaboutgsr)
Ooof. Probably a loose bolt, there are two that hold the caliper to the U-shaped bracket, and two more that hold the whole caliper and bracket to the hub. Check the bolts to make sure the threads are still good, and torque them down.
Old Aug 7, 2003 | 07:40 PM
FF-sean's Avatar
you need bigger wheels
maybe calipers were loose....
Old Aug 7, 2003 | 08:00 PM
Dancing is Forbidden's Avatar
Default Re: brake caliper rubbing (ReaL JDM Eg6)
I would take the wheel off and check all the bolts to make sure that they are all tightened. If those are all tightened, I would look for other defects.
Old Aug 7, 2003 | 08:02 PM
Philip's Avatar
Default Re: brake caliper rubbing (EF9_SiR)
i just took mine off to paint the center of my rotors black. When I put them back together, I used loctite on the 4 bolts that hold everthing on.
Old Aug 8, 2003 | 05:59 AM
PupaScoopa's Avatar
Default Re: brake caliper rubbing (Philip)
Not exactly the bolts that I would choose to come loose...
Old Aug 8, 2003 | 07:28 AM
mrcch's Avatar
Default Re: brake caliper rubbing (PupaScoopa)
Do you have aftermarket calipers or rims? How long since you have done anything to them?
spens 91 Ef
Jul 10, 2009 01:09 PM
sayyeah
Dec 23, 2007 01:01 AM
93gsrcoupe
Mar 28, 2006 11:07 PM
lv6l
Jan 22, 2006 07:28 AM
JDM H22
Oct 4, 2005 09:13 PM
