Emergency brake help
Old Aug 7, 2003 | 06:20 PM
slooogsr's Avatar
Default Emergency brake help
for some odd reason my emergency brake light keeps flashing on and off every so often.......... driving home from work it stayed on for 5 mins.............. before you ask my e-brake was totally off and i pulled over to be sure..........
could this be a sign of needing to change my rear shoes? also my emergency brake cable needs to be adjusted so im thinking it may be because it is loose.......... any ideas would be sweet.......
Old Aug 7, 2003 | 06:24 PM
FourthGenHatch's Avatar
Default Re: Emergency brake help (sloorex)
The Brake Fluid in your Master Cylinder is low.
Old Aug 7, 2003 | 08:02 PM
slooogsr's Avatar
Default Re: Emergency brake help (FourthGenHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">The Brake Fluid in your Master Cylinder is low.</TD></TR></TABLE>
good suggestion....... lol......... gonna check first thing in AM
Old Aug 7, 2003 | 08:35 PM
photonjedi808's Avatar
Old Aug 8, 2003 | 10:03 AM
slooogsr's Avatar
ok it was definitely low...... now i have to figure out where its leaking............ doh!
Old Aug 8, 2003 | 10:18 AM
EL Vap133's Avatar
Default Re: (sloorex)
check your calipers, ususally you can see the leak.
b18b1ef8
Apr 18, 2008 05:31 AM
spintboy
17
Jan 3, 2008 08:49 AM
tthomass
Nov 14, 2006 05:42 PM
Hatchd
Jul 28, 2003 08:43 AM
iperez
Jul 14, 2003 09:36 PM
