Difference in RSX & RSX Type-S (160HP Vs 200HP)
Old Aug 7, 2003 | 05:09 PM
skribblah's Avatar
Default Difference in RSX & RSX Type-S (160HP Vs 200HP)
What is it about the type S ( dont know engine codes yet, think its K20A2 ) that makes it 40HP more than the baseline model ( K20A3? ) ?
Old Aug 7, 2003 | 05:17 PM
Davanca's Avatar
Default Re: Difference in RSX & RSX Type-S (skribblah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah &raquo;</TD></TR><TR><TD CLASS="quote">What is it about the type S ( dont know engine codes yet, think its K20A2 ) that makes it 40HP more than the baseline model ( K20A3? ) ?</TD></TR></TABLE>
Well for one the Type-S has a 11.1 compression ratio, while the base model has 9.8.to 1, also the the Type-S has different cams thats why it has a higher redline than the base model. This pretty much makes the extra 40 horses. Then you have the other features but they don't really play a part in the HP, like the 6-speed manual tranny.
Old Aug 7, 2003 | 09:16 PM
skribblah's Avatar
Default Re: Difference in RSX & RSX Type-S (davanca24)
dam gravy. thanks
Old Aug 8, 2003 | 03:24 AM
AussieK24's Avatar
S has a performance form of VTEC and base has an emission form of VTEC. Ports are bigger in S. Compression is higher in S (as previously stated).
Old Aug 8, 2003 | 07:37 PM
GreenBean's Avatar
Default Re: Difference in RSX & RSX Type-S (AussieB20vtec)
The type S has vtec on both the intake and exhaust cams. Audible while in stock trim and you can also feel it. The base model has that secondary intake valve that opens up to like another 10.0mm or something. trust me!!!! Drive both and your brain will tell you the better of the two. Also the Type-S has some mechanical differences like fiber reinforced cylinder walls that the base does not have. the S has an oil cooler where the filter mounts...the base does not...
Remenber the base and ep3 civic si have the same engines.
Old Aug 9, 2003 | 02:56 PM
skribblah's Avatar
Default Re: Difference in RSX & RSX Type-S (GreenBean)
very nice responce dude. thanks for the info ;]
hockeyMike2489
14
Jun 4, 2006 08:21 AM
HondaTek
Feb 11, 2005 09:08 PM
ak1ra07
Dec 3, 2003 07:25 AM
Adampops
Jan 8, 2002 09:14 PM
