high idle
Old Aug 7, 2003 | 03:25 PM
ithrowpoop's Avatar
Default high idle
when i turn on my headlights, rear defroster or heat my idle raises to 1000-1100 rpm's. when the light are off and none of the other stuff is on the idle is normal at 750 so i have not adjusted it. the motor is stock, with i/h/e and no p/s or a/c. please help.
Old Aug 7, 2003 | 03:29 PM
vtec.dc2's Avatar
Default Re: high idle (ithrowpoop)
sounds normal.. thats how stock ecu runs the car..
Old Aug 7, 2003 | 03:46 PM
K20DC2R's Avatar
Default Re: high idle (vtec.dc2)
that sounds pretty normal. the eld( electronic load detector) adjusts the idle thru the idle air controll valve to raise the the idle so the alternator can produce enough energy for the used items ( p. lights/air blower/ etc) hope that helps.!
Old Aug 7, 2003 | 07:38 PM
hYpE-R-29's Avatar
its NORMAL..u should hold the drivers side window button up and then see what happens to your idle
b20bFourDoorCivicLX
Honda CR-V & Element
Oct 10, 2013 06:35 PM
axis11
May 16, 2013 08:16 PM
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
Shaguar47
Dec 12, 2004 11:22 AM
diLUDEd
Aug 24, 2002 09:55 AM
